dell 4050 restarts
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    dell 4050 restarts
    my dell 4050 restarts automatically. i opened the motherboard. no heat related issue.
    what to do?
  • ahsansmiles
    • Aug 2013
    • 7
    • Pakistan
    Re: dell 4050 restarts
    Can you elaborate? How does it restarts? Did you meant you reach until Windows and during work it gets restarted automatically?
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • MMH3
      Dell Precision 3450 small form factor - BIOS cannot be opened in FIT - please help clean
      by MMH3
      i would appreciate, if someone could help me.
      DELL: 3450 sff
      Servicetag: (!) obviously FAKE - ABC2345
      Mainboard: 0GK35Y - serial /ABC2345/CNFCW0023800L6/
      Chipset: Intel W580 (Rocket Lake PCH-H)
      BIOS: 1.34.1
      ME: 15.0.50.2633
      mor data can be found the HW-Info-data in the rar-file
      I have this BIOS from a DELL Precision 3450 SmallFormFactor mainboard i bought refurbished.. from china.
      The board itself works without any issues.
      My goal was to clean the ME of this and fully...
      09-13-2025, 11:54 PM
    • Rekoo1997
      DELL Precision 3520 powers on automatically
      by Rekoo1997
      Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
      Issue: The laptop powers on automatically after being shut down.
      Actions Taken by Technician:
      BIOS reflashed
      Intel ME region cleared
      Result: Issue still persists
      Additional Observations:
      Power button reads 3.3V (normal)
      The problem occurs both when running on battery and when connected to AC adapter...
      08-07-2025, 08:48 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
