Del N5010 not powering up. CK=DC chip burning hot.
  • DCJack
    • Apr 2013
    • 26
    I'm working on an abandoned Dell N5010 that looks to have good power and the power supply sounds good, but when power is triggered the power supply squeals.
    I took the board out and powered it on the bench, everything measures good, all FETs pass, but there is one chip that runs burning hot. It is a tiny (probably 4mm x 4mm) with the following markings:
    Line1: CK=DC
    Line2: H1Q
    Line3: .
    The third line is obviously a "pin 1" indicator. Plugging the codes into Google gives me nothing useful and I have never come across this chip before.
    Anybody know what this little guy is?
  • spidey
    climbs
    • Dec 2012
    • 648
    • Cyprus
    Re: Del N5010 not powering up. CK=DC chip burning hot.
    it is rt8205. +3v and +5v power ic.
    • dycc
      Vision
      • Nov 2011
      • 624
      • Côte d'Ivoire
      or tps51125
      • spidey
        climbs
        • Dec 2012
        • 648
        • Cyprus
        Originally posted by dycc
        or tps51125
        yes it is the replacement for rt8205A not B.
        • dycc
          Vision
          • Nov 2011
          • 624
          • Côte d'Ivoire
          probably have a short on +3v or +5v that is why this chip runs burning hot. desolder coils to find if the short belong to the chip (CK=DK or rt5205 or tps51125).
          • dycc
            Vision
            • Nov 2011
            • 624
            • Côte d'Ivoire
            is there a difference between A and B @spidey
            • spidey
              climbs
              • Dec 2012
              • 648
              • Cyprus
              According to datasheets;
              pin 18 on A is NC,
              pin 18 on B is LG1_CP (Alternative LGATE1 Output for 14V charge pump).
              pin 18 on C is SECFB (to monitor the optional external 14V charge pump)
              I've never seen "C", btw you can use B instead of A. Sometimes opposite is possible but first you have to check schematic about pin 18.
              thats why tps51125 is replacement for B. I was mistaken in my post before it is not A.
              • DCJack
                • Apr 2013
                • 26
                How did you guys find out what the chip was by the little information I provided. I must learn your secrets!
                • spleenharvester
                  • Mar 2010
                  • 882
                  This! I'd love to get into board level repair a lot deeper but I think most people here have some sort of advanced electronics qualifications.
                  OP if you can't get anywhere you could buy another faulty board and start swapping parts over. It's worked for myself before.
                  Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                  • DCJack
                    • Apr 2013
                    • 26
                    I am doing some Googl'ing trying to learn how removing the chokes will help me find my short. I feel like I'm missing some basic electronics principle.
                    • DCJack
                      • Apr 2013
                      • 26
                      I lifted all the large filter coils (was incorrectly calling them chokes) and the chip(Label 1 in image) is still burning hot, so I removed it. When I applied power back to the board the left most FET(Label 2 in image) became burning hot, so I removed it. Reapplied power to the board and the right most FET(Leble 3 in image) became burning hot to the touch. I replaced all the components I removed but kept the coils lifted and now write this post.
                      Should I keep going?
                      • dycc
                        Vision
                        • Nov 2011
                        • 624
                        • Côte d'Ivoire
                        after you replaced all the three chips . check if there is always a short between the pin of the two tantalum cap
                        • dycc
                          Vision
                          • Nov 2011
                          • 624
                          • Côte d'Ivoire
                          ptc4603 and ptc4602
                          • DCJack
                            • Apr 2013
                            • 26
                            Both of the caps test good out of board but the contact points show continuity to ground.
                            • dycc
                              Vision
                              • Nov 2011
                              • 624
                              • Côte d'Ivoire
                              now you need shematic to resolve this issue. you have to check all components (one by one) bound to those short-circuit . it mean that all the components supplied by 3.3v if the short is on this voltage and the same for 5v if the short is bound to it. tedious process
                              good luck and you really need it
                              • DCJack
                                • Apr 2013
                                • 26
                                Ignore this post, Pin16 is no longer shorting to ground.... I am so confused.
                                Found something interesting...
                                When I measure pin 16(VIN) on PU4601 it shows short to ground and Pin8(VREG3) and Pin 17(VREG5) do not show short. How is the chip getting hot if there is no power getting to it because of the ground short at pin16?
                                P.S. I found the schematic...
                                • DCJack
                                  • Apr 2013
                                  • 26
                                  Looking at the schematic I see that PTC4603 has a source voltage from +5_PWR. I can't find anywhere on the schematic where this +5_PWR is being generated. I want to start tracing components from this source.
                                  Another interesting thing... Even though the +3.3v_ALW is shorted as shown by PTC4602, to ground the power button has it's 3.3v trigger.
                                  • whaldsz
                                    • Apr 2013
                                    • 395
                                    • Philippines
                                    If it is short for both +3.3_ALW and +5_VALW, it's likely that you need to replace PU4601. +5_PWR Comes from +5_ALW.
                                    • prabhucna
                                      • Aug 2011
                                      • 3
                                      hai hello , how do you say that its rt8205. +3v and +5v power ic.
                                      • prabhucna
                                        • Aug 2011
                                        • 3
                                        did you got mb circuit diagram
