HP DV9000 again
  • Alfa is auto
    • May 2013
    • 83
    • Finland
    HP DV9000 again
    So im thinking to make xtra fan for gpu and it does fit under the chassis&bottom case ..dc5 v 0.19 amps but witch is the best way the to get that 5v?can i connect to original fan?i doubt that..
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: HP DV9000 again
    You can, in fact, connect to the original fan. Red wire is +5v, black wire is ground. But the fan you attach will not benefit from the speed control, it will just run maxed all the time. You'll need a bit more circuitry to accomplish that if you desire.
    A working TV? How boring!
    • Alfa is auto
      • May 2013
      • 83
      • Finland
      Re: HP DV9000 again
      OK,thanks for reply,thats all what i need to know,will do some mods before doing all that thing.And fan is EL silencio
      • nichella14
        • 29
        • Philippines
        Re: HP DV9000 again
        usb port +5v alfa dont connect to the original fan
        • Alfa is auto
          • May 2013
          • 83
          • Finland
          Re: HP DV9000 again
          Yep ok, i was thinking about it ..so will do the usb ports.
          • dpiroli3
            • Dec 2012
            • 12
            Re: HP DV9000 again
            how about a copper shim on the gpu instead of the fan?
