Hp pavilion dv6000 white screen with vertical lines
    Hello everyone
    I have here Hp Pavilion dv6000 white screen problem with vertical lines.
    When I turn it on, no bios, hard drive led no light, what do you guys think the problem is, SB chip?
    I connected to external LCD but not detecting, I know all hp laptop supports external LCD auto detect.
    I also tried known working memory no luck
    Then I reballed the gpu still the same.
    The next thing I want to do is to change the gpu with a new one (Nvidia G86-730-A2)
    Any idea how to fix it?
    Thanks in advanced
    JT
    Re: Hp pavilion dv6000 white screen with vertical lines
    check the lcd cable, make sure its sitting properly, i have one of these and i replace the gpu and its been fine apart from the fan running fast very often(bios update by hp)
      Thanks for reply Sparks88
      LCD cable is ok. i'm gonna go ahead and order new gpu, i'll post back the result.
        how are you reballing (ir bga or hot air gun)
          I use both upper and lower ir.
          problem solved.. it was lcd screen..
          i seperated the lcd from the laptop, then hooked it up to an external lcd.
          works both on vga/hdmi.
          Thanks for your time!
            try to disconnect the lcd flex cable first in your motherboard and plug your external monitor,,
            if the lcd flex cable is connected to motherboard, external monitor only appear after the window startup most of dv series
            you cannot use external monitor if the Operating System is not loaded or no Operating system
