Samsung R510 no video fault
  • scobie_21
    • Jul 2011
    • 144
    Hi I have this unit I have tested all voltages all seem ok.
    I have cleaned the ram slots still the same.
    I have swapped processor still the same
    I have reflow the GMCH still the same.
    The Clock generator seems fine, strange thing is I cannot get a reading off the ICH crystal with my frequency counter.
    I have no mch3_lcdvddon V from GMCH to Gate of Q2 so no LCD_VDD3V to video connector which seems to point to Gmch if Im not mistaken.
    Another question does anybody know exactly what signal frequencies I should be getting from the Clock Generator apart from the 14mhz to Ich and the 48mhz to Ich usb controller?.
  • Anndy
    • Aug 2012
    • 10
    Re: Samsung R510 no video fault
    If you have multiple RAM sticks, try one at a time (could be a bad one causing it)
    Also, trying an external monitor would be a good idea (just make sure you press the correct key combo to switch the output)
    • scobie_21
      • Jul 2011
      • 144
      Thanks Anndy but I have tried all the obvious stuff. This a bit deeper and more technical I suspect either ICH or GMCH not sure which, most probably GMCH due to no LCDVDD voltage on lcd connector.
      • Anndy
        • Aug 2012
        • 10
        This is a bit too technical for me, but here's my two cents, instead of trying
        to fix it, you could just take the easy out and get the motherboard replaced!
        It should have a part number on it, if you look it up on ebay or google, odds are
        you'll find a seller who sells it for a reasonable price.
        • scobie_21
          • Jul 2011
          • 144
          Thanks but that defeats the whole point of repairing electronics. Swapping out boards is Swaptronics not Electronics and is the easy way out .
          • Francisco.s
            • 686
            • Spain
            Hi scobie_21, can you upload the schematic, or put a link to it?
            Have you tried with an oscilloscope?
            • Anndy
              • Aug 2012
              • 10
              Maybe so, but let me give you another perspective, if the problem seems too difficult to repair and you can get the motherboard replaced on the cheap, why not? just think about it. Is it really worth spending days or even weeks of your time trying to repair a device you can cheaply replace?
              • retiredcaps
                • Apr 2010
                • 9271
                It all depends on what scobie_21 wants. If he wants to learn more about electronics, component level troubleshooting and repair is a good way.
                Recently, I wanted to learn more about how multimeters work so I spent days troubleshooting a broken $5 garbage multimeter. I finally found the problem and fixed it. It works, but I'm unlikely to ever use it on anything other than batteries.
                Some might think I'm crazy since I could have just bought another $5 multimeter, but I learned a lot and I was willing to spend all that time doing it. In fact, I have 3 more dead $5 multimeters and I'm planning to fix them and I hope each one has a different problem so I can learn.
                Obviously each person has their own value system wrt to time and money so there is no correct answer.
                --- begin sig file ---
                --- end sig file ---
                • kenttech16
                  • Oct 2011
                  • 27
                  • Philippines
                  Agree! It's worth trying specially if you have fixed and learned from it. Eventually, the rest will not that hard to troubleshoot then..
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    Yesterday, 10:54 PM
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
