What should I do.. ? (Dell N4030)
  • error2007
    • Feb 2013
    • 7
    • Indonesia
    Hello..
    I Have dell Inspiron N4030.. The Problem is PCB Board are demaged
    You can see in this image :
    The question is.. What should I do to repair this problem.. ??
    i bring N4030 Schematic in attachments
  • brethin
    • Dec 2008
    • 1907
    Re: What should I do.. ? (Dell N4030)
    If it is just a broken trace it shouldn't be a problem for someone that can solder.
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      solder a wire to make connection to broken traces.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
        Dell Inspiron N4030 Laptop Schematic
        09259-1 Arsenal DJ1 DIS...
        10-31-2024, 04:09 AM
        Dell Inspiron N4030 Laptop Boardview
        Dell Inspiron N4030 Laptop Boardview...
        10-29-2024, 04:40 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
