HP 6735b/6535b memory issue
+ More Options
Posts
  • bollin
    • Mar 2013
    • 104
    • Finland
    I have got an hp 6735b where the motherboard died. It is equipped with the wwan module, but since replacement boards are expensive and I don´t want to waste that much money on it I ordered a as is board for a 6535b (basically the same, but without the wwan socket). I am going to move the socket later, first I need to get it working.
    The problem is that when both memory slots are occupied, it won´t post. Num lock & Caps lock blink three times, which indicates memory.
    But, when I remove memory from slot 1 (under the keyboard) it powers up.
    It doesn´t matter which one of the memory sticks I use, it simply wont power up with both slots occupied.
    The next step was to check the CPU, since the memory controller is on the cpu. So I changed to another known good processor, but still the same.
    What could cause this? There is a row of resistors (ddr2-damping), but I don´t believe that it is a resistor since nothing is burnt or anything.
    There might be a shorted pin somewhere in the slot, but at the first inspection everything seems ok.
  • Francisco.s
    • 685
    • Spain
    Re: HP 6735b/6535b memory issue
    Hi bollin, have a look to this link:
    http://www.ebay.es/itm/DDR2-memory-s...item4aa962e532
    DDR2 memory slot tester card for laptop motherboard.
    • spleenharvester
      • Mar 2010
      • 900
      Was the board bought as working? Might just be worth sending it back matey. Sounds like you've more or less narrowed it down to the board, unless it's an odd pair of sticks.
      EDIT: Oh wait I see it was as is. Sorry :/
      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • spidey
        climbs
        • Dec 2012
        • 644
        • Cyprus
        try bios update, and try to use same ram modules. is it an amd system ?
        • bollin
          • Mar 2013
          • 104
          • Finland
          I will try to update the bios, it might be bad since everytime it boots up after I´ve tried starting it with memory in slot1, I get a message that the bios was restored.
          It is an AMD system
            Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
            This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 06:21 AM
          • kokodin
            memory mod for amd radeon r7 260x
            by kokodin
            Hello, for almost a year i been trying to make something that seems impossible, or my testing software is lying to me and it works only i can't see that.
            I been trying to mod a memory on radeon hd7790 or 260x from 2 to 4 gb, but it doesn't seems to be as simple as i first thought.
            In theory 2 workstation graphic cards using the same graphical processor have 4gb of memory firepro w4300 has 4 256x32b layout and W5100 has 8x 128x16b layout all use gddr5 memory and internals of the bioses seems to be very similar so i was trying to wing it , but so far it seems either tserver can't show...
            03-28-2024, 03:48 PM
          • Kocane
            HP 840 G1 laptop wont start due to memory module issue
            by Kocane
            I have this EliteBook 840 G1 laptop that won't start - it blinks on the caps- and numlock buttons 3 times which indicate issue with the memory modules. On one of the memory slots of the motherboard, I can see some corrosion (?) and my guess is that it's creating a short. At first I figured I could just omit using this slot but it wont start either way - also tried other RAM sticks of course.
            I've tried to see if I could clean it up, but the laptop remains unbootable. Can it be because it has caused issue elsewhere or because it's still shorting in the memory module?
            11-18-2023, 04:34 PM
            Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
            This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
            Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
            07-07-2024, 02:34 PM
