how to bypass cooling fan on demand speed?
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    hi,
    i am having thermal problem with this laptop -sony vaio vpcee32fx.
    i'd like to bypass the on demand speed, would like to make it at full speed
    always.
    there are 3 wires from mobo to fan.
    thanks for any solution
  • Lumberjack777
    • Dec 2010
    • 464
    Re: how to bypass cooling fan on demand speed?
    Originally posted by fddizon
    hi,
    always.
    1 wire is power. 1 is ground. and the other is speed control. If you disconnect the speed control wire, it should run at full speed.
    On a DV9000 there are 4 wires on the fan. The red is the power and the black is the ground. What I do since I can't quite handle the full speed sound of the fan is to add a 6 ohm resistor on the red wire. Then it's always on and cools the cpu and the gpu, but it's running at a level I can tolerate.
    If you have a red and black wire that's probably the 2 that you need. Even if that's not the 2. It won't hurt the fan, it just won't run. You need to find the power and ground. Mine are red and black.
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      lumberjack,
      thanks for the idea. i remember way back doing that, but the laptop gave me an error to check the fan. it wont let the laptop to boot. i hope this sony vaio laptop is not the same.
      thanks
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        can i put carbon type resistor 1/8 watts?
        • Lumberjack777
          • Dec 2010
          • 464
          Yes, and you can experiment. I started with 2 ohms. Too loud. Then 4 ohms. Same thing. I settled for a 6 ohm resistor for the balance between cooling and noise. I used GPU-Z and CPU-Z to monitor the temps also until I got just the right balance on my temps and fan noise.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            On 3-wire fans the middle wire is RPM sensing, not speed control. Speed is controlled by varying the DC voltage on the power wire. You can disconnect the power wire (red) and wire it straight to a 5 volt supply for full speed. Check where you wire it beforehand - you don't want to wire it to the standby power supply and have it spin even when the laptop is off.
            A working TV? How boring!
            • c_hegge
              • Sep 2009
              • 5219
              Precisely. That 3rd wire is indeed a tachometer. Fans that have their own speed controllers have four wires.
              I modded my my Toshiba A200's 3 pin fan this way. I used the HDD's SATA power connector as a source of 5V.
              • Lumberjack777
                • Dec 2010
                • 464
                Ahhhhh, interesting. Good to know. Thanks for the correction.
                On my DV9000's, the GPU's are all running at 40c to 50c now. They get close to 60 on my BurninTest 3D Graphics max load program. One customer said before I did the fan mod it hit 88c
                I had to reflow it for him. He uses a cooling pad with the fan mod, and said it has never gotten above 50c
                • fddizon
                  • Sep 2011
                  • 555
                  • Philippines
                  does the 3 wired fans all the same regardless of wire color? center wire is colored red, yellow and black on sides.
                  • spidey
                    climbs
                    • Dec 2012
                    • 648
                    • Cyprus
                    never look the colors, always measure.
                    And for a full speed, get +5v from usb +.
                    • fddizon
                      • Sep 2011
                      • 555
                      • Philippines
                      how about getting 5v from a usb port? will it degrade the port for using it?
                      • Elysarian
                        • Mar 2013
                        • 200
                        I was always under the impression that decent fan controllers used a PWM circuit to vary the speed, not a varying DC level?
                        the higher the mark/space ratio (more "on" time) the faster the fan will spin as the voltage average will be higher.
                        This is done to avoid a scenario where the fan stalls due to insufficient voltage.
                        Of course modding the fan to have a permanent voltage instead of the output from the speed controller will still cause the fan to run at a constant speed though.
                        I can't see that the tiny current drawn by a small fan would affect the USB ports too much myself unless you're close to maxing them out already.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          I've done it before and it works just fine.
                          Only on 4-wire fans, which have a speed controller built-in. You'll have a hard time getting a normal (2-wire or 3-wire) fan to accept a PWM signal. On the other hand... on non-PWM fans that varying DC level *is* generated via PWM internally in the drive IC.
                          • c_hegge
                            • Sep 2009
                            • 5219
                            It will slightly reduce the amount of current the port can supply, but not by much. If you just use the port for something less power hungry (like a mouse), it will be fine.
                            It's probably the yellow wire, but as others have said, measuring the voltage is always a good practice. Sometimes, the fans will also have the wires labelled on the PCB
                              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 05:27 AM
                              Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                              This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                              This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                            • Hondaman
                              Liquid cooling?
                              by Hondaman
                              I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                              (After previous generation hardware [Gigabyte] didn't...
                              05-08-2025, 09:37 PM
                            • Carlos#2003%
                              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                              by Carlos#2003%
                              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                              02-15-2024, 07:52 PM
