HP dv9000 problem
  • scobie_21
    • Jul 2011
    • 144
    HP dv9000 problem
    Hi I need assistance please. I was reassembling a Dv9000 AT1/2 and I inserted the ribbon cable from the small power pcb attached to the fan incorrectly into cn10/cn7 as opposed to cn9/cn8. No the unit wont power on. I have short circuits on
    pc43
    pc44
    no pc45.
    (VGA_CORE)
    I took out PL11 to see if IC PU10 was faulty but still SC.
    Pc140
    Pc138
    All short circuit.
    Any ideas would be great
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: HP dv9000 problem
    check the ribbon cable an make sure ends are good! had ps3 ribbon ends cross traces!
    • scobie_21
      • Jul 2011
      • 144
      No cable is fine Im sure something is damaged I just cant find it
      • Tuomo
        • 163
        • Finland
        pc43
        pc44
        no pc45.
        (VGA_CORE)
        Pc140
        Pc138
        All short circuit.
        VGA_CORE has very low resistance so it is possible at there is no short circuit.
        Is there VIN voltages or +5 and +3.
        • scobie_21
          • Jul 2011
          • 144
          Yeah I have 5vpcu, 3vpcu I was missing the 1.2v from pu1. I was getting Vin but no 1.2 out so I replaced PU1 now it switches on and immediately off again the 1.2v can be measured via pq2 and pq1. Any ideas ? would bad bios do this as originally I was reflashing the bios when I plugged the cable in the wrong connector
          • scobie_21
            • Jul 2011
            • 144
            Addition to previous comment I meant after I had flashed the bios with my external programmer, I was re-assembling the cable to test machine when I plugged into CN10 by accident...
            I have since changed the bios chip but still led4 flashes and power led1 flashes fan spins and it turns off then on again in a loop..
            Any ideas on what to check next would be appreciated as I am at a dead end now..
            • Tuomo
              • 163
              • Finland
              It sound like protection fault, but then it should shut down.
              What connector swithed? Cable meant to CN?? go to CN10?
              Try first look where this CN10 go and check those chips.
              If this not works, you have to go step by step boot voltages.
              • Tuomo
                • 163
                • Finland
                By the way do this motherboard works before your actions?
                DV9000 series have very often NVIDIA chipset problems.
                This case you should reflow/reball those chips.
                • scobie_21
                  • Jul 2011
                  • 144
                  Yeah but it was not detecting DVD or HDD I suspected the MCp reball but then I did the stupid thing with the ribbon cable is supposed to come rom cn2 on the small board situated on the fan and it supposed to go into cn 9 on the mobo but i put it into CN10 .
                  I checked PU6 ISL6236 and couldnt get 5vAl and 12vAlw so I changed it out for same and no power again so I changed it back now no power again still. Im just going round in circles.
                  Is there a website which explains what all the different voltages do and what the terms like 3vpcu mean ?. I have experience in Electronics but not with laptop motherboards that much.
                  Thanks for the assistance
                  • Tuomo
                    • 163
                    • Finland
                    Unfortunately I dont know that kind website, if this website not count.
                    3VAL, 5VAL, 12VAL means it allways ON when AC Plug or Battery is inserted.
                    Rest of the voltages come after you press the power button.
                    If I understand corretly there is no 5VAL, this is needed for booting.
                    So if 5VAL missing this is first think to checking.
                    • alihomee
                      • Dec 2012
                      • 1577
                      • malaysia
                      from where to check 3val 5val and 12val
                      • Tuomo
                        • 163
                        • Finland
                        DV9000 motherboard.
                        Let start 5VAL, PU6 PIN 7 LDO, you can measure voltage on PC60.
                        If there is no 5V, measure resistance and if low, remove PR76 and measure again.
                        This case it seems at 3.3VPCU and 5VPCU are allways voltages, they can be measured PL14 and PL15.
                        • alihomee
                          • Dec 2012
                          • 1577
                          • malaysia
                          acctualy i have presario f700 with same problem
                          • alihomee
                            • Dec 2012
                            • 1577
                            • malaysia
                            and i already post my thread in troubleshooting laptops page
                            • scobie_21
                              • Jul 2011
                              • 144
                              I am about to give up on this unit, I replace PU6 because of no 3vpcu but I had 5vpcu no difference, Pq50 was reading short so took that out still reading short on all pins, lifter pl14 both sides reading short, pq25 reading short, pq19 short.
                              I think I will bin this unit
                              • scobie_21
                                • Jul 2011
                                • 144
                                This thing has a mind of its own, I switched it on this morning now Im gettin 3.3v on pl14 and pl15 5v it now switches on by itself and fan runs full speed.
                                • Tuomo
                                  • 163
                                  • Finland
                                  Can you check KBC operation conditios?
                                  • scobie_21
                                    • Jul 2011
                                    • 144
                                    When the power is on now and fan running full speed the KBC controller is getting very hot.
                                    I will do some more investigations later I have put it away for the moment to repair another board
                                    • theone111
                                      by theone111
                                      3. Problem: TV shuts down
                                      07-22-2024, 10:36 AM
                                    • Zeonalbasta
                                      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                      by Zeonalbasta
                                      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                      09-13-2024, 01:17 PM
                                    • Gibon378
                                      Problem with stopping audio and video for no reason
                                      by Gibon378
                                      PC Specs:
                                      • CPU: Ryzen 5 1600
                                      • GPU: GTX 1080 Palit JetStream
                                      • MOBO: ASRock ab350 PRO4
                                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                      • PSU: XFX 650W (don't remember what model)
                                      • OS SSD: ADATA SP920
                                      • OS: Windows 10 21H2
                                      Problem description:
                                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                      11-19-2022, 09:41 AM
                                    • perzyk23
                                      Lenovo T580 - LCD Panel problem - error 0288
                                      by perzyk23
                                      Good morning,
                                      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                      10-25-2024, 12:42 AM
                                    • lazaro.089
                                      Asus Zephyrus M16 / GU603ZW problem
                                      by lazaro.089
                                      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                      CPU: Core i9-12900H
                                      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                      08-26-2025, 06:33 PM
