hi to all of you!my macbook pro 13 mid 2010 don't recognize optical drive.i change the drive with a new one and the same problem.i even put a hdd caddy(an optical bay to replace the optical drive with a hard disk)but the same problem.where should i search on the motherboard?or is someone else who have this problem too?this is very imprtant to me because i want to put my 750gb hdd on the caddy optical bay an put a ssd hard disk like master. thank's a lot.
Re: macbook pro 13 mid 2010 don't recognize optical drive
hi spidey.i havo no schematic.i think is the southbridge ,as "thesloc" suggest.but i'm afraid to reflow it because is my personal laptop not a client laptop!
and the laptop is working very well except the problem with the optical drive that i described.others ideas?Comment
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by perfm2So I've worked on dozens of HP and Dell laptops and have never encountered this before.
Steps taken in my usual process.
Reset security settings in the BIOS
Ensure existing HD comes up into the OS
Shut down the laptop and disconnected the main battery
Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
Replace battery connector and close up the laptop
Insert my USB drive with my Windows 10 image I've... -
Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
Channel: Schematics and Boardviews
10-22-2024, 02:37 AM -
by madura2010Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
i checked the connectivity of ribbon=good communication with hard and motherboard
changed hard disk and checked=3f0 error persist
sata power=+5v available
Then checked data capacitors=all good
Then checked data lines path connectivity to pch=all good
reflashed... - Loading...
