AM4835EP Replacement???
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Good Day Everybody
    I Have A problem About May Repair HP Compaq Presario CQ40-310AU
    Problem Before Shorted in Charging. If i Insert The Adaptor in a Laptop the Light-Power Indicator Has Been Off.
    Althougth i Trace The Problem i remove PQ103 here the Schematic diagram
    now the Short Has been gone The Adaptor Light indicator Led Stable Light.
    I Worry About the This Part PQ103. were i can take this parts. but i have lot of Mother Board. but they no same in this part. i dont Know what is Compatible for AM4835EP Replacement??? i hope have...
    Any one can know what is the replacement of this AM4835EP Transistor?
    Thank's
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    Re: AM4835EP Replacement???
    To: Mods
    Sorry have Multiple post
    Would you Delete this... it Wrong Thank's
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      it is a mos-fet 30v p-channel. desolder from one of the motherboard you have. doesnt need to be the same numbers exactly. any p channel from motherboard will be ok. most of them are the same. you may also search datasheets.
      • lorins_core
        BlackSmith
        • Dec 2012
        • 552
        • Philippines
        Can You Teach Me How to Identify what is Compatible?
        Look this
        https://www.badcaps.net/forum/showthread.php?t=26451
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          just compare datasheets. use google to find them.
          • lorins_core
            BlackSmith
            • Dec 2012
            • 552
            • Philippines
            only sale this part... would you help me to Find?
            • spidey
              climbs
              • Dec 2012
              • 644
              • Cyprus
              if you have motherboards, desolder the mosfet which is 30v pchannel. thats it. search google to find data sheet to compare. very easy.
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                http://www.ebay.co.uk/itm/5pcs-AM483...a240f4cb1#shId
                http://www.analogpowerinc.com/part.php?part1=AM4835P
                http://www.analogpowerinc.com/part.php?part1=am4835ep
                  HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook 800 Specification for Upgrade or Repair
                  This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                  09-06-2024, 08:50 AM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
                • the_rem
                  Unknown transformer : how to find a good replacement part ?
                  by the_rem
                  Hello guys,
                  I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                  I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                  04-23-2025, 01:48 AM
                • ezenia
                  PS4 controller left stick potentiometer replacement issue
                  by ezenia
                  Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                  So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                  I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                  09-30-2023, 02:19 PM
                • boosti45
                  Macbook pro logic board replacement parts quesion
                  by boosti45
                  i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                  08-21-2024, 05:23 AM
