DV6-2003eo random power off
  • yakideo
    • Feb 2013
    • 16
    • Sweden
    I'm happy to be new here. I have a HP DV6-2003eo laptop that has some kind of intermittent power failure. Most of the time the computer starts (fan on, LEDs on) and then shutdown after a couple of seconds and sometimes it starts just fine to later shutdown and again fail to power on.
    The same thing happens when running from DC-power, battery or dock.
    I've have monitored the CPU/GPU temp to make sure that I'm not tripping any thermal shutdown. eg. temperatures looks good.
    I have checked most of the N-channel mosfets and electrolytic caps. ("On the N-Channel FET place the NEG lead on Pin 6/7 and the POS lead on Pin 2/3. You should get a reading of some value ~100 to 500 or higher.")
    I don't know where to start my diagnostic - since the problem is occurring randomly. What could be the most likely cause?
  • welhim
    • Feb 2013
    • 40
    • philippines
    Re: DV6-2003eo random power off
    try to reflow the video chipset...miled only..
    • welhim
      • Feb 2013
      • 40
      • philippines
      much better if you have pictures on it
      • yakideo
        • Feb 2013
        • 16
        • Sweden
        I doubt that a reflow will help since I do get picture and the computer stays on (once it decides not to turn off before POST) enough time to do a video/cpu benchmark. Plus, this is a newer dv6 model, hopefully not suffering from the previous BGA defects.
        Pictures of what? The entire motherboard?
        • Tuomo
          • 163
          • Finland
          I fixed DV6 2106eo with same type fail.
          There was condensator shorted on 1.1V output.
          • yakideo
            • Feb 2013
            • 16
            • Sweden
            Can an capacitor that measures 8.9 ohm be considered shorted?
            • Tuomo
              • 163
              • Finland
              I think if measure first +- and turn over -+ it should be very high resistance.
              • gabik111
                ORD spotter
                • 142
                • USA / Poland
                It depends if or what other components are paralelly connected with it on the board.
                Laptops and computers repair.
                • Tuomo
                  • 163
                  • Finland
                  Voltages which go CPU or GPU have very low resistace.
                  You can take CPU OFF and measure resistace to CPU coil.
                  GPU voltages remove capasitors and measure then capasitors.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                    03-31-2024, 02:12 PM
                    09-06-2024, 05:59 AM
