PM_I_hpc_s mv_mb_v3
    Re: PM_I_hpc_s mv_mb_v3
    nop wrong i was cheking the chipset rom , the main spi bios is ok , she got 3.3 volts on pin 3 7 and 8
      Excuse me for asking is EC bios different from KBC bios? Thanks
        Do you have any chance to plug a full battery and try to power on then ?
        Because you have similiar symptoms as I 've encountered before.
        Remember, never ever connect two adapter pins together, it blows the charger chip. Use original HP charger.
          also i dont get VCC +3.3S on the KB , also notice i should have on pin 33 of ITEkb , and ther eis no voltage there , as also there is no rsmrst as well ..i got some 3alw voltages on KB , but not main vcc
          Which schematic are you using?
          Did you check voltage at pin 8 of EC-BIOS?
            im using hp_g62_compaq_cq62_foxconn_star_federer_rev_1.0_sch , cheked EC bios there is no voltage there only on sprom , for what i can manage and understand after cheking schematic is that there is some anomaly on s3 state , since some os the voltages that shouldbe present are not there, therefor kb will not work properly
            im now trying to find out why i dont get 5 volts on main dc dc , and since i dont have that voltage i also dont get 5Val on the tsp51117 (1.5v ddr3 and outher smal voltages ) cheked that PQ762 should have on pin 3 voltage there due to RUN_on_load therefore i can't get as well any voltage for +3S , since i dont have this voltage i also can't have VCC on kb controler (should be +3S and its 0)
              EC bios , 0.39 volts
              poin 3 , 7 and 8
              spi rom
              3:30 on pin 3 7 and 8
                poin 3 , 7 and 8
                spi rom
                I can't tell how I sure about that charger chip.
                  poin 3 , 7 and 8
                  spi rom
                  You should check +V3.3A at pin 8 of UI6. (EC SPI ROM)
                  Also check EC_ALW_EN and PWR_SWIN# signals are both working properly.
                    like i mentioned before , spi rom , got 3.30 volts on pin 3 , 7 and 8
                    for EC_alw_en got 0 volts
                    for PWR_SWIN got 3.29 volts
                      Then, reprogram UI6.
                        ok , i will reprogram the bios with the latest version i'll find in the website of hp and i let you know
                          EC-bios is the same as kbc bios. (UI6, page 25)
                          PCH-bios (or main bios) is US2. (page 13)
                          Some motherboards have the code of EC-bios integrated in the PCH-bios, so only one bios chip is needed. It is connected to intel PCH chip.
                          Regards.
                            Thank you very much Francisco, I really appreciate it
                              reprogramed u16 , (before i add changed the chip by another board i had here and nothing happen, even like this i reflashed the bios with the latest bios update , and the same , no DC jack led , and no 5 volts .
                                Check KBRST#_D voltage and 32KXCLKO/32KXCLKI frequency.
                                --STAR(FEDERER)--
                                  Check RSMRST# if 3.3v is present.
                                  But the lack of 5v is also a concern. You must fix this first.
                                    rsmrst = 3.30 volts .
                                    not having 5 volts is what is driving me nuts , could this be like powersaver issue ? since there is no short on the god dam line rail ....
                                      What do you get at pin 7 and pin 27 of PU850?
                                        Just laughing and reminding u the charger chip again
                                          guys mine is working but there is no +VDD_CORE voltage on my motherboard, so no power at GPU chip, what is possibly causing that ? any help will be appreciated.
