Macbook pro 15 black screen.
  • primoz1
    • Oct 2010
    • 270
    • Italy-Slovenia
    Hi again. This laptop it power Up but screen is black, fun spins on full power al the time and DVD start, and no shows other signs of life.
    Is that nvidia defect or some other, I ask because I see a lot of videos on youtube and in almost all nvidia cause this defect.
    Is any suggestion, how to resolve this problem ?
    Thank you.
  • primoz1
    • Oct 2010
    • 270
    • Italy-Slovenia
    Re: Macbook pro 15 black screen.
    I reball GPU and work, but I got two problems.
    Laptop start, let sound OK, but after show white screen and folder with question mark ?
    • heavymachines
      • Mar 2011
      • 1028
      corrupted os or need to reinstall os-x do a smart check on hdd see if its bad with aida or speedfan after you connect the hdd to a windows based pc of course.
      • heavymachines
        • Mar 2011
        • 1028
        sometimes if you wait long enough it will boot not always but i have seen it...
        • primoz1
          • Oct 2010
          • 270
          • Italy-Slovenia
          Aha, so this is probably defected OS problem or bad HDD ?
          • lord
            • May 2011
            • 319
            • Croatia
            Yes. This is the sign that the OS cant boot. You can take out the disk and boot from Hiren and do a disk check. If the disk is OK you have to reinstall OS. The best way to install OS is to download MacOS and make a bootable USB stick (the optical drives on this ones are problem prone).
            Boot from the stick and enter disk utility. Partition the disk as GUID and make a HFS partition. Install the MacOS and everything should be OK.
            • primoz1
              • Oct 2010
              • 270
              • Italy-Slovenia
              Hi. I use hiren's boot CD and boot OK, but no one tool can start (some error) but HDD is still in laptop. Whole thing is heating too much for my opinion (like 70 deg celsius) ? I got feeling to somethig wrong with GPU, maybe reball was not successful ?
              So what can I do to exclude defective motherboard ?
              Im not familiar with Mac at all.
              Thank you.
              • lord
                • May 2011
                • 319
                • Croatia
                Hm maybe.
                Try to boot hiren without HDD.
                Did you clean the coolint system? Do both vents work fine?
                • primoz1
                  • Oct 2010
                  • 270
                  • Italy-Slovenia
                  Hi. I try without HDD and work OK http://youtu.be/ymXDsgp44eE
                  Fans and cooler is clean no dust etc. fresh thermal paste but still is little warm for my taste, but I hear that serie is heated a lot.
                  I dont have any MAC OS dvd etc. (is not my laptop) so I cant test is hdd or corrupted OS.
                  Thank you.
                  • lord
                    • May 2011
                    • 319
                    • Croatia
                    you can connect the hdd to another laptop and check the disk
                    btw šiješ me za pet postova
                    • primoz1
                      • Oct 2010
                      • 270
                      • Italy-Slovenia
                      I speak with owner and he say -is 90% to bad HDD, because get this problem few time before- So i think (hope) that case is closed
                      Thank's for help.
                      "samo 5, uff moram da odma napucam eno 20 postova" prijatan božič i nova godina. LP
                      • seanc
                        • Nov 2008
                        • 1319
                        I think (because I have one) that these laptops are built to use the casing as a heatsink.
                        If it had an nVidia 8600m, it might have been covered by Apple for free repair, but you've got it fixed anyway.
                        • primoz1
                          • Oct 2010
                          • 270
                          • Italy-Slovenia
                          Hi. I get laptop to repair and I dont ask if is under warranty, if owner does not care, I dont care either
                          • Baileybum1234
                            • Sep 2012
                            • 245
                            Just looking at this post. I have an Apple powerbook G4, do you need a special lead to connect your hard drive to an intel based laptop? I just notice they look like a special Apple connection but might be wrong.
                            Repaired: LG50PQ6000
                            • seanc
                              • Nov 2008
                              • 1319
                              Hard drives in all Intel Macs are SATA. The one in your PowerBook will be IDE. You are best off putting your PowerBook hard drive in a 2.5" USB to IDE enclosure and pulling the data from it.
                              • primoz1
                                • Oct 2010
                                • 270
                                • Italy-Slovenia
                                In my case got connector like that KLIK
                                • HTR-Informatique
                                  Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                  by HTR-Informatique
                                  YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                  I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                  On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                  I also changed the screen because the PC fell and the screen was broken.
                                  I changed the battery with a new and original battery.
                                  I also had corrosion/oxidation on the...
                                  02-09-2025, 06:51 AM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • VcemPzd
                                  Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                  by VcemPzd
                                  Hello everyone !
                                  My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                  04-28-2025, 10:14 AM
                                • DaniK
                                  Acer Aspire E5-574-52RH - black screen
                                  by DaniK
                                  I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                  Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                  Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                  Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                  The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                  Symptoms are:
                                  - random black screen after displaying Acer logo...
                                  02-21-2024, 06:27 AM
                                • turmix
                                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                  by turmix
                                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                  During another reassembly, I made a mistake, and...
                                  01-29-2024, 03:48 AM
