Asus A42J shutdown itself after a few minutes
  • farid multintech
    • Apr 2012
    • 37
    • malaysia
    at first i think there is problem with the processor.already change with another but condition still the same.any idea,thanks
  • lord
    • May 2011
    • 319
    • Croatia
    Re: Asus A42J shutdown itself after a few minutes
    Can you measure the temp of the CPU and the NB?
    • tomodachi
      • Apr 2012
      • 610
      • Turkey
      First of all take out BIOS battery and short pins, then check if there are any liquid contacts on mobo, these mobos usually does not come with GPU or chipset problem,
      if no good result, upload a picture of mobo please
      • farid multintech
        • Apr 2012
        • 37
        • malaysia
        how to measure without enter window,what tool can be use?
        • farid multintech
          • Apr 2012
          • 37
          • malaysia
          ok i will try
          • pctek
            • Apr 2012
            • 53
            • Greece
            Have you tried a bios update (if there is any ) ?
            • farid multintech
              • Apr 2012
              • 37
              • malaysia
              ok i will try flashing bios later,now im focusing on other laptop,urgent!! thanks for your suggestion
              • lord
                • May 2011
                • 319
                • Croatia
                You can use a multemeter which measure temperature. Put the temp probe on the cooler above the cpu and the measure the gpu.
                This is the easiest and the cheapest way. You have those low cost multimeter at any electronic parts store for 15$.
                • farid multintech
                  • Apr 2012
                  • 37
                  • malaysia
                  ok i will try
                  • Amraks
                    • Nov 2011
                    • 725
                    I know its a long shot but any luck with this problem?
                    I have cleaned the fan, applied new heat sink paste.
                    after 10 mins - 15 mins laptop will shut down.
                    • Amraks
                      • Nov 2011
                      • 725
                      I think I cleared the problem it doesn't like some harddrives.
                      I suspect their harddrive went then they tried a new one and gave up.
                      installing a updated bios seems to have stopped it shutting down randomly at the moment getting further in my windows install i suspect the harddrive I am using is POS.
                      • Amraks
                        • Nov 2011
                        • 725
                        Alright so far so good.
                        No random reboots, benchmarked on gpu. I assume it was a bios bug using with different hdd's
