Dell 5010 no power
  • laptop market
    • Sep 2012
    • 122
    • mansoura
    Dell 5010 no power
    Changed iC power,ck=ck
    There are 3 volts on key electricity but no volts on the BIOS and
    There are volt outside exit 3-volt battery
    Who have no problem
  • mohamed.mostafa
    • Sep 2012
    • 40
    • egypt
    Re: Dell 5010 no power
    عندي نفس المشكلة
    • PantherDave
      by PantherDave
      Hi all!
      I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐Ÿ˜…
      05-29-2024, 02:01 PM
    • Mark01
      Dell Optiplex 7490 AIO - red power led after flash
      by Mark01
      Hi guys,
      This is my first post! ๐Ÿš€
      I have no idea what Iโ€™m doing, but Iโ€™m learning by trial and error.
      Iโ€™m currently working on a Dell Optiplex AIO 7490โ€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
      07-04-2025, 12:54 PM
    • zlr8r
      Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
      by zlr8r
      hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
      Ill try and give as much info as I can.
      Dell Inspiron 17 (7786) Laptop
      Service Tag: 5J0NHT2
      Bios: 1.9.0
      When I received this , it would only flicker on the KB backlight for a second, then off and on.
      Then it started getting weirder!
      Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
      12-12-2023, 09:31 PM
    • LimesKey
      Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
      by LimesKey
      Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
      10-17-2025, 05:33 PM
    • seppde
      Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
      by seppde
      I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
      My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
      Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
      Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
      10-01-2024, 10:57 AM
