Toshiba Satellite L355D...STILL NO VIDEO!!!
  • thesloc
    Banned
    • Dec 2011
    • 587
    Toshiba Laptop L355D. Switched board TWICE, and still NO VIDEO. I'm guessing I got sent a defective one two times.
    Everything boots up, lights come up, but nothing on display. NOTHING. Nothing shows up while connected to the VGA port on an external monitor either.
    I'm guessing:
    -Bad GPU (on both boards)
    -Bad VGA connector (not physically on board, but a cable that runs to it)
    Bad inverter/lcd???
    Gonna send it back again, I guess..
  • thesloc
    Banned
    • Dec 2011
    • 587
    Re: Toshiba Satellite L355D...STILL NO VIDEO!!!
    Anyone???
    • pctek
      • Apr 2012
      • 53
      • Greece
      Can you hear a windows intro sound ? Hdd activity led ? If yes it means it passes the boot procedure and there is another problem (lcd connector ,cable etc ) . If not , the motherboard is faulty
      • primoz1
        • Oct 2010
        • 270
        • Italy-Slovenia
        Are you push FN and F5 when tested with external monitor ? If primary screen is not connected on motherboard then lapptop self detected external monitor, otherwise it is necessary to press buttons for switch to external lcd.
        • thesloc
          Banned
          • Dec 2011
          • 587
          Good question. I have not heard a windows sound because I don't have a harddrive for it (well, there's nothing on it, it's clean). I should probably check for HD activity. Anyway, nothing shows up when connected to external monitor.
          • thesloc
            Banned
            • Dec 2011
            • 587
            yes sir, i pres FN and F5 to toggle between monitors. Nothing happens on external monitor.
            • primoz1
              • Oct 2010
              • 270
              • Italy-Slovenia
              I see now, you get defected board two times 110% Where you buy this ? I got bad experience with IPMART anf TOTOBAY and some sellers from ebay too. If not work on first try, send it back immediately. Just make shure if is memory moduls and processor OK and check if is power voltage stable, must not waste-drop any voltage
              • artois7
                • Mar 2011
                • 159
                Have you kept any components the same, ie CPU, ram etc? Possibly a bad CPU?
                • johnwafu
                  • May 2012
                  • 17
                  • philippines
                  check if you have a netokin below the proc, replace it with 2x 330uf capacitor.that should work,can you post screen shots on below and bottom of the mobo?near proc.
                  • primoz1
                    • Oct 2010
                    • 270
                    • Italy-Slovenia
                    This laptop is without nectokin element.
                    • thesloc
                      Banned
                      • Dec 2011
                      • 587
                      I switched the ram, but not the CPU.
                      • johnwafu
                        • May 2012
                        • 17
                        • philippines
                        is your proc heating up upon booting?
                        • thesloc
                          Banned
                          • Dec 2011
                          • 587
                          hmmm it does not. i just sent the board back and should get an exchange.
                          if this doesn't work i'm not sure what could work
                          • artois7
                            • Mar 2011
                            • 159
                            Try a different cpu.
                            • thesloc
                              Banned
                              • Dec 2011
                              • 587
                              Alright, tried it again with a different board = still no video! wtf!!
                              Skeptical that it's the CPU, or I'm gonna give up on it all together.
                              • thesloc
                                Banned
                                • Dec 2011
                                • 587
                                JUST replaced new CPU, and NOTHING. GRRR.
                                Anyway to test the mobo by itself? When I connect the dvd-drive it spins it and 'reads' it, so I get sounds. There is no HD led activity, only the sound of the hd spinning somewhat (faintly).
                                Is there a linux distribution that will play a sound upon boot up?
                                I can't see anything on the video, the proc has been replaced (it gets warm), RAM modules switched, etc.
                                If this is a bad mobo, then I have been fucked three times already.
                                How do I test the lcd screen by itself to rule that out?
                                The VGA out on the mobo is also connected/dependent on cable that runs to the casing, so it's not integrated in the mobo (cable). I'm going to replace that too.
                                • b700029
                                  Banned
                                  • Sep 2010
                                  • 640
                                  That's autonomous behaviour it'll do as long as it gets power, you can disconnect the signal cable and it'll still do that. The same with the HDD spinning.
                                  You can see if the CPU is getting Vcore and check for a clock signal on the FSB. Probe the BIOS's data pin with an oscilloscope and you should see activity as it initially loads the boot code. The same goes for checking for signals on the video out and LCD connector. Even if your scope's bandwidth isn't high enough, just seeing something other than background noise is enough to confirm that things are happening.
                                  The OEM model should be Inventec PS10AP. Schematic:
                                  http://lqv77.com/download/652/
                                  Don't blindly replace trivial parts like cables without testing for continuity first.
                                  • thesloc
                                    Banned
                                    • Dec 2011
                                    • 587
                                    Someone at technibble has the SAME problem (he swapped out pretty much every part)
                                    http://www.technibble.com/forums/sho...ighlight=l355d
                                    IS THIS REAL LIFE??
                                    • kiranfocuz
                                      • Jun 2011
                                      • 12
                                      i can help you - give your laptop part number .
                                      • Bl4ckw1d0w
                                        • Apr 2013
                                        • 3
                                        I had all the symptoms described and had been searching forever for a solution. I tried pulling everything out one by one to see if any external parts were the issue, then it came down to the motherboard. I was so frustrated, I wanted to throw it all out the window. Then I remembered an old trick of baking graphics cards in an oven to re flow loose not very concrete solder joints. Granted I wasn't about to stick a motherboard in my oven. So Picked up a heat-gun off eBay with an adjustable temp and wide nozzle set it at 480 and low enough pressure not move anything out of place and evenly heat up the board on one side. Left the processor in socket and the heat sink still on. You want to be careful not to bump it or even move the board a little bit because parts are so small they can easily be displaced. After a good 15 mins I could see the solder liquefy a tad and let the board cool off for a good 4 hours at-least to be safe. Flipped the board over and did the same thing on the other side after it was cool. To my amazement the laptop fired right up after I left it overnight too cool. The screen on an everything like the day I bought it. I hope this helps someone.
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:10 PM
                                          Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
