The hp v6000 has had a wireless problem identified and HP had a program up until Jan to do a free repair on some models. The problem is not with the wifi card but is with the mother board. My question is has anyone here experience this problem and if so can anyone offer a fix? Without replacing the mother board or using a usb adapter? I have done some searching but have not found a fix. I have seen one post where the tech over stressed the cpu and claimed to have fixed the problem? Any help from the experts.
HP Presario v6000 wireless problem
Re: HP Presario v6000 wireless problem
Ya the V6000 has had a problem where the wireless connection just disappears for no good reason. The WiFi light is red even if you turn the switch on or off. The device do not show up in the device manager so installing a device driver is not an option. I understand that it may be caused by overheating?Comment
If your laptop is AMD based, there's a huge chance the GPU (Graphics) is going out,this is one of many issues of result of failure GPU, non-functional WiFi, sound...and finally it goes a time you the screen stay black when you try to power on your lappy, google HP laptop failure GPU WIFiComment
hello!
that I understand, your only problem is with wireless?
the icon disapears in windows? and you can't see it in device manager?
if this is? in the bios, the wireless is actived?Comment
maybe, you haven't the wireless card plugged in the laptop?Comment
It's the nVidia GPU/northbridge. You'll need to reflow it to make it work again. This is one of the initial warning signs that your GPU is dying. Economically, you are much better off just cleaning out that heatsink and installing a nano-USB wireless for $10-$20Comment
I know a USB is an option as a mater of fact I am using one now. I understand that eventually I will loose the video? Already I have two vertical lines on the screen. I am not sure if these are related to the problem? I am thinking of re-flowing if I can get enough info to build my confidences.Comment
Well, this depends really. The better you can actually reach ~220C the better and longer it will last. Of course you will need professional tools to pull this off. In my experience, you're probably better off doing nothing until it actually dies (no video). This could be months or years. Doing anything DIY at this point could do more harm than good. I'd stay with the USB wireless and wait it out OR take it / ship it to a professional who can reball the GPU.Comment
By professional tools I assume a good heat gun? I have read some forums where they have revived the wireless by this method?. I also assume that re-balling is rather expensive and I am not even sure if it is even available in Eastern Canada? So all in all it is cheaper to purchase new than to repair???
http://www.ebay.com/itm/431364-001-C...ht_1487wt_1163Comment
The problem is you stand a far better chance of ruining the GPU than actually fixing it (even with a decent heat gun). No heat gun is going to get you a permanent fix - even re-work stations costing thousands won't be a permanent fix. A properly done reflow will only net you another 6-8 months tops. Your still getting video which is a good thing. The other option is to purchase a refurbished motherboard from a reputable source on ebay and outright replace the motherboard. I've seen dv6000 boards for $60-70. In fact now that I think about it, this would be a far better option for you. Like this one:
I'm thinking the lines are a separate issue. Does your model have dedicated video ram? If so, then the problem could be there; if shared memory then its probably just an LCD issue.
Yes - the boards you find online are usually reworked boards and will probably fail again eventually. Considering the DV's had near 100% failure rates your chances of finding one that will work for an extended period are going to be slim. What I would do is email the people selling these and ask if they've been reworked. I would try and find one that hasn't had problems "yet". Keeping it cool is the only thing you can do to help. Keep the heatsink clean and dust free. Flash ads, playing videos online (again.. flash) and games will cause the most stress on the GPU so keep these to a minimum. These laptops were billed as a multimedia machine and as such got put through the ringer by consumers. They just aren't cut out for it though.Comment
^ The chances of it reoccurring again with a replacement board are high, it's somewhat a mystery why this laptop has even lasted as long as it has unless it wasn't used very often.
Screen corruption can be a symptom, or it might not be. Depends which solder balls break first, what goes out before the whole thing stops working. FWIW, I had a DV6000, it failed under warranty and I had HP repair it by putting a new mainboard in. Got it back, confirmed it worked and sold it to a friend cheap with him knowing the history of the system. It still works for him at the moment but his wifi has already failed (again).
I'd get any valuable data off, keep using it with a USB wifi dongle, then when it dies someday part it out and sell everything but the mainboard on ebay. It should last longer if you don't let the northbridge/GPU get very hot, for example not playing 3D games or watching GPU accelerated video (movies, youtube, adobe flash, etc).Comment
^ I doubt that will matter, sub-optimal heatsinking of the CPU could slightly REDUCE the problem, if the CPU were to get hotter then the fan would ramp up in speed sooner and the northbridge would be cooled better. It is ironic that this is the situation when so often we think a cooler CPU is better but not when the same heatsink is used for both chips and fan RPM is determined by CPU temperature.
The penny trick or equivalent improvement in heatsinking could reduce the chances or degradation rate, of further damage but with there already being signs of damage present, it seems a bit futile. It is certainly something you could try if the system is valuable to you but I would assume it will be dead within a year either way.Comment
Also, if you have not updated the bios, HP released a BIOS that ramps up fan speed sooner to cool the northbridge better. Of course it will be a bit louder. Be sure the system is 100% stable if you attempt to update the bios.Comment
Thanks 9999... I did take the BIOS up grade, didn't notice any problems. I will just take your advise and wait for it to die completely.Comment
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by litsnsirnI have an Alienware Aurora R12 desktop and I recently just started reloading the hard drive after replacing one that failed. After reloading the wireless will not work. It comes up in the Device Manager as Intel AX201 and has the warning symbol and if you click into it, it says ‘Code 10 Cannot start’. I’ve tried uninstalling everything that seems related in the software center and the driver, and have tried reloading with two of the different files that I sourced from Dell and a driver package directly from Intel and after reinstalling, it winds up in the same condition that it started....11-19-2024, 11:14 AM
This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
This specification for the HP ProBook 430 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Backpack & Wireless Premium Mouse boardview and 430 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 03:30 PM
- Loading...
