Ram Repair for GBA mounted chips
  • andy smethurst
    • 49
    Hello, I purchased a laptop at an auction with a 2gb ddr2 ram card inserted,but I was getting ram error beeps every time I turned it on.
    I tried it in 2 other laptops, and was greeted with the same error beeps.
    This is a Hynix 2gb ddr2 module, and noticed that all the chips on the board are grid ball array mounted. I also noticed a sign of rough handling as it had deepscratches on one side where it locks in to the slot.(no track dammage)
    I suspect bending and poor handling may have separated one or several of the soldered points on one or more of the IC's.
    I have repaired video chips on laptops with GBA conections, using a heat gun and no-clean up flux.
    Could the same procedure fix a problem in this situation?
    Has anyone out there tried this with failure or success?
    I would very much like to hear from anyone who has attempted this.
    I think I will try it anyway, as I have nothing to lose,and seeing that this GBA method of soldering components is getting more popular in industry, we people who repair electronics without very expensive equipment will have to find alternative methods of repair, or throw it in the bin and buy new all the time, and look for new hobies and interests,other than electronics.
    Thankyou for any Ideas.
    master hoarder
    • May 2008
    • 12175
    Re: Ram Repair for GBA mounted chips
    I would say try washing the RAM first as perhaps there could be something conductive stuck under the chips.
    ... Yes, I said washing . (water, liquid detergent, then dry for a day or two).
    If that doesn't work, then try the reflow. Since this is a RAM module, I would suggest reflowing in a oven rather than with a heatgun, unless you have some thermocouples and can monitor the temperature of the chips (it's rather easy to overheat the chips with the heatgun, and that can kill them).
    If using the oven, set it to 240C and put the RAM (with flux under the chips) in it. When the oven reaches 240C, wait for about 3 to 5 minutes, then turn it off, and carefully open the door (i.e try not to make the oven vibrate too much). DO NOT take out the RAM until it has cooled down.
    • andy smethurst
      • 49
      Well I didn't get to try the washing method, as I jumped in and tried the reflow method with a hot air gun, with no positive results.
      I would say that you are right about the oven heat supply, as there are many chips, and on both sides at that. Not knowing which individual chip is playing up, makes it almost impossible to decide where to apply the heat in this method. This may not have been the problem in the first place,as Ram dose fail. If surface mount with legs were used it would be easy to decide,as you would have a visual indication,and save time from using these procedures.
      • ugamazing
        Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
        by ugamazing
        I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
        08-31-2022, 07:34 AM
      • DennisH
        Need Help Identifying This DIODE mounted on a Frigidaire oven control PN:316131600
        by DennisH
        This diode is mounted on a Frigidaire electronic oven control PN:316131600. This diode runs hot enough that the PCB is showing slight burn marks (black soot looking area on PCB above the diode). It looks to me to be coming from the body of the diode.
        The oven control is 22 years old and still works, but I can't get a new replacement, so I'm doing preventative maintenance and replacing a few parts on it that I think could fail - and this is one of them.
        Can any of you identify this diode (see pic) and suggest a replacement that can handle more heat - or if not, can...
        10-18-2022, 07:24 PM
      • feherhollo
        WSON8 NEW Bios Chips READ, ERROR, ETC.
        by feherhollo
        I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
        I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
        For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
        11-26-2023, 09:33 AM
      • Fsufan1391
        LG Oven model LREL6325F
        by Fsufan1391
        Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
        04-23-2025, 05:42 AM
      • schnauzer2021
        Chasis bond to neutral to overcome oven tripping problem
        by schnauzer2021
        I have a 6 years old Rowenta table top oven. The oven have both convection and grill function.
        Last Christmas I used it to roast a turkey with the convection mode for about 4 hours without any problem. When I switched to grill mode to deep browning the turkey for the final half hour, the power trips after a while.
        I have not been using the oven since then. Last week, when I try to use the oven again, both convection and grill mode trip the power supply a few minutes after turning it on.
        As I was too busy with my work, I leave it to the repairman...
        09-13-2021, 02:40 AM
