Sony vaio VPC-EB mbx223/ no start,no power no led
  • sebuncle
    • Jun 2010
    • 46
    • France
    hi ,
    motherboard M960 rev1.1 mbx223
    doesn't start , no led , no power , no charge.
    I check on power button 3v are no present
    19v is present on PF1 and PL1.
    19v is present on PQ2 but only on pin 1 to 4 , on pins 4 to 8 there's 0v (i change PQ2 it's the same)
    i check SN608098:
    no voltage on pin 3 and 6
    i check BQ24753A:
    PVCC have 19v
    Can you tell me where i have to check
    i don't have schématic
    thank you
    JOVY RE7500
  • lat123
    • Sep 2012
    Re: Sony vaio VPC-EB mbx223/ no start,no power no led
    I had the same problem and I was able to fix it by grounding pin 4 (In your picture it is the top left pin) directly. Initially I measured 19.4V at that pin but the IC does not function unless it is grounded and the other three pins are at 19.4V. Hope that helps solve your problem.
    • fabiog
      • Jul 2011
      • 102
      Have a similar problem with another Sony ,how do you ground that pin?
      • shoesforsale209
        • May 2013
        can you describe pin 4 in more detail. Are you talking about the first ground wire (according to the pic) from the power jack. I interested in this repair because I have a MBX223 motherboard no longer showing any signs of life after three months of usage. I change the power jack and the power board, but still nothing. I've attempted to try your grounding method, but i was unsuccessful at it as i'm not sure if i'm grounding the correct pin. What is pin 4?
        • Tuomo
          • 163
          • Finland
          Originally posted by sebuncle
          hi ,
          thank you
          Measure PU3 PIN5 ACDET.
          This detect if AC Power is inserted.
          Measure PU3 PIN4 ACDRV# should be LOW.
          • shoesforsale209
            • May 2013
            I found the problem. The PU3 (BQ24753ARHDR) (NS982402) is not functioning at all because i'm not getting a reading. I checked pin 5 (ACDET) and Pin4 (ACDRV) nothing. I have 19.4v from PF1 and PL1. I assuming the PU3 is dead should I replace it?
            • Tuomo
              • 163
              • Finland
              Not yet, first check PR13 and PR14.
              Then measure PQ1 voltages.
              • aimiliano
                • Jun 2014
                • Greece
                i have the same motherboard but with slightly different problem.. it starts but it doesn't give the vga voltage
                • OHENABA
                  • Aug 2014
                  • 6
                  • GHANA
                  Hi, i have similar sony mbx223...will like to know if any have the solution or can help...19v is present on PQ2 but only on pin 1 to 4 , on pins 4 to 8 there's 0v. PQ2 was changed but still.
                  • Blacktek
                    • Nov 2014
                    • 250
                    i have the exact same issue on my mbx-224. On PQ1 im getting approx. 19v on all 8 pins and on PQ2 i get same voltage on pins 1-4. PR13 and PR14 tested ok, i have their right values but PR14 i get 19v on one en and 0.5v on the other end, which is why i get 0.5v on pin 5(ACDET) on PU3. Ping 4(ACDRV#) i get 18.7v.
                    Any help, clues or ideas would be appreciated.
                    • Blacktek
                      • Nov 2014
                      • 250
                      When i remove PU3 i get 2.7v on pin 5, still nothing on PQ2 draining pins.
                      thankx
                      • tata123
                        • Nov 2013
                        • 104
                        I had the same Problem but with MBX-224 but its the same structure check the PQ1,PQ2, and the most important the are the Capacitators PC168 and PC169.
                        I have upload a picture witch you can find the parts.
                        The failure is NO LEDS NO START NOTHING!!
                        • Blacktek
                          • Nov 2014
                          • 250
                          Thanks for the input buddy! but those 2 caps are ok,but i found that something is shorted to ground in the line of PL18(+1_05V_VTT), i removed all PC206,PC208 and PC212 but still same thing, even with PU16 removed i still have the short. Also PQ2 and PQ1 seem to be ok, except that im able to switch them on/off while in circuit...is that normal??
                          • tata123
                            • Nov 2013
                            • 104
                            unsolder the PQ CHIPS AO4433 and check it up!!
                            Dont unsolder the BQ QFN CHIPS if there is higher voltage...
                            • maestro_lpc
                              • Mar 2015
                              • 14
                              • Georgia
                              Try bios reset. Remove rtc battery and short 2 pins. Or there are bad short ceramic capasitor in out tranzistor 19v.
                              • Blacktek
                                • Nov 2014
                                • 250
                                Thanks Maestro_Lpc .. Tried that but no luck. all caps around pq2 are giving the right values when removed from the board. Can you think of anything else i can try?
                                • bicalov
                                  • Nov 2014
                                  • 294
                                  • Netherlands
                                  How this story ended? I have the same issue and I would like to know.
                                  • neky
                                    • May 2009
                                    • 21
                                    • Croatia
                                    aimiliano , flash bios ,should solve your problem
                                    • ravi_1617
                                      YY Solutions
                                      • Jan 2012
                                      • 343
                                      • India
                                      Same board mbx223,board starts and off. Again on by itself. Cycle. On and off., actually it's accident case. Lan coil L70.and Web cam connter pulled off when slipped from hand. Screen part also came of.
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Just jumper pin1 to pin5 of pq2 and power the mb. if you get 3.3v on battery connectors probably it will work. Wont charge battery though. Very common fault with mbx223/224 mb.
                                        you should make jumper with very thin cable so that it should blow off if there is some short in the mb. If it blows off then look for 19v line. there must be short. usually capacitor goes short near cpu socket where 4-5 mosfets are located.
                                        Hope it helps
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
                                          Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                          Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                          This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
