bad capacitor on atx 250 12z
  • pedromed
    peter
    • Feb 2012
    hi gays!. I had a problem with psu on compacpresario pc. The green led was off. I change two caps (680 uf 200v) one was bulky. the green led lit with a frecuency about1 seg. I following searching for a caps with dark glue and find de C36 2200uf 10v, with this characteristics and change this. The result is fine the green led is on!!
    and the psu is working. thanks to badcaps forum
  • severach
    • Aug 2007
    • 1055
    Re: bad capacitor on atx 250 12z
    Good job. If you only replaced a few capacitors it will fail again. That's OK if it's yours. That's how you learn what works and what doesn't.
    sig files are for morons
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • Wolf1977
      define a value of capacitor that writes 5n6j 1200volt ahas green color
      by Wolf1977
      hi
      in a pcb circuit drive a fluerescent lamp
      there is a component that writes 5n6j 1200volt ahas green color
      on the place writes c4 thats mean is capacitor and there is shunt whith multimeter
      i test the lamp without this but again it doesnt light
      can you tell me what value is this component ;
      10-03-2023, 08:39 AM
    • jimjoe123
      LCD TV Green/Pink screen problem
      by jimjoe123
      I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
      Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
      Then each time...
      02-23-2020, 01:29 AM
    • Agent24
      Dick Smith Q-1760 linear power supply filter capacitor question
      by Agent24
      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
      It has at least one problem.
      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
      I have already ordered a replacement potentiometer, so that's not an issue.
      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
      All are CapXon...
      10-21-2025, 05:39 PM
