not switching
  • ismy4real
    • Dec 2011
    • 87
    not switching
    pls can any body here help with my CQ61 not switching and i check the battery terminal the normal volgate is there to charger and power it.dont know what to do pls
  • severach
    • Aug 2007
    • 1055
    Re: not switching
    Any recent mishaps with your Compaq laptop, such as dropping it on the floor? Does that model have a power led at the jack?
    sig files are for morons
    • ismy4real
      • Dec 2011
      • 87
      Re: not switching
      not there is no mishaps or drop on floor , it work with battery alone when i charge the battery some where it work but with charger is not working .
      • b700029
        Banned
        • Sep 2010
        • 640
        Re: not switching
        So it doesn't work with the adapter at all?
        Schematic: http://lqv77.com/download/546/
        Power circuitry is on page 31. Starting at DC JACK in the upper right corner I would check all the components between +VA and +VIN. I suspect the MOSFET PQ48 is open.
        • ismy4real
          • Dec 2011
          • 87
          Re: not switching
          have you check the power session of the board , i still don't can't fix it pls help me
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            Re: not switching
            check the pu4 chip and the pr199(220 ohm) resistor near the battery connector .also check pr183 resistor near the memory slot.
            • ismy4real
              • Dec 2011
              • 87
              Re: not switching
              i will check it and let you know.
              • dycc
                Vision
                • Nov 2011
                • 625
                • Côte d'Ivoire
                Re: not switching
                0k
                • ismy4real
                  • Dec 2011
                  • 87
                  Re: not switching
                  check the pu4 chip and the pr199(220 ohm) resistor near the battery connector .also check pr183 resistor near the memory slot. have check all what you gave me but still not switching, when i lifted the PR199 there will not be any voltage at battery terminant. i don't know what to do again.
                  • ismy4real
                    • Dec 2011
                    • 87
                    Re: not switching
                    still need help
                    • dycc
                      Vision
                      • Nov 2011
                      • 625
                      • Côte d'Ivoire
                      Re: not switching
                      the pr199 should have 22ohm value at your multimeter not 220 sorry.
                        03-31-2024, 02:12 PM
                        07-01-2024, 06:34 AM
                        After all of...
                        07-13-2024, 08:14 PM
                        DVR camera recorder switching power supply capacitor failure really
                        These cheap non brand capacitors at it again
                        Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                        Well at least I have the cameras back on line I to try the...
                        01-22-2022, 06:28 PM
                      • michel74
                        How does this switching PS work ?
                        by michel74
                        Yes ! How does this switching PS works ? :-)
                        I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
                        Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
                        11-02-2023, 12:35 PM
