Aspire 8920G reboot
  • astrosofia
    • May 2011
    Aspire 8920G reboot
    Hi guys,
    my name's Riccardo from Italy
    i've this problem:
    Aspire 8920G reboot when loading Windows .. exclude hard disk and GPU (already replaced).
    the notebook works fine in safe mode and and loading windows xp live from USB
    tomorrow I will receive the Peak esr70 for test bad capacitors, it is possible that the problem is some bad capacitor?It may be under stress could cause the problem?
    Bye
    Ric
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Aspire 8920G reboot
    Have you tried a Linux livecd? That sounds more like a software problem to me.
    • Joun
      • Jul 2011
      • 191
      • Greece
      It seems like a graphic card problem to me..I have seen it a few times before.What happens is that windows loads fine until they load graphic card driver.
      That "stretches" the card causing reboot.If I remeber correctly your laptop has an separated graphic card.Maybe you can find someone with the same laptop and borrow his card.
      Otherwise with a reflow you will be sure if it is the card to blame.
      P.S You can see what card is compatible with your laptop here: http://forum.notebookreview.com/acer...els-cards.html
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        • PC's, The Experts Exchange (same name there), Gardening, Hot Rods.
        If you read what the OP wrote the video card was already replaced.
        If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
        Subscribe to support us. It only takes 1 minute:
        https://www.badcaps.net/settings/subscriptions
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Slightly possible.
          Laptops don't usually use Lytic caps so they have fewer caps problems than desktops.
          The problem is -after- the OS is installed to the hard drive ??
          • Joun
            • Jul 2011
            • 191
            • Greece
            You're right but since it is a little hard to find the right card for a laptop,(a lot harder than finding a hard disk) maybe he ment CPU not GPU?
            After all it is a whole separate board not just a GPU..
            • astrosofia
              • May 2011
              I've already replaced 2 video cards and rule out the hdd excluded as well (the customer's and my) .. is the cpu or the motherboard IMHO
              • astrosofia
                • May 2011
                If you think this list can not create the restart issue?
                • Joun
                  • Jul 2011
                  • 191
                  • Greece
                  Are the video cards you replaced compatible with this list? What card is it? Is it 9500M GS, HD 3650, 9650M GS, or 9600M GS?
                  • astrosofia
                    • May 2011
                    definitely not the same video card, but it could give the same problem?
                    • senndogg
                      • Dec 2011
                      • 383
                      • Albania
                      • electronics, cars, speed...
                      Hello!
                      I know that this topic is outdated but i still want to share my experience so maybe others, even by googling, can benefit.
                      The same case arrived 2 days ago in my store.
                      Acer Aspire 8920G. Rebooted every 3-5 minutes. Wont let you install/format anything.
                      A clue was that, if unplugged from AC it could stay around 10 minutes without rebooting.
                      So, after stripping i realized that this notebook used the infamous Nec Tokin proadlizers, responsible for the Toshiba Satellite L300 freezing issue.
                      Swapped that and now the laptop working like a charm.
                      Note: You can find the discussion and guide on repairing in this forum if you search for L300 freeze.
                      Thank you!
                      • ilprincipedeimostri
                        • Feb 2013
                        • 8
                        • italy
                        Same problem.
                        I solved with Nec/Tokin replacement as described in this post:
                        http://www.informaticanapoli.it/prob...nto-acer-8920/
                        Big thanx to astrosofia for his help.
                        Regards
                        • comasutra
                          • Apr 2015
                          • 21
                          Thanks a lot.
                          This fixed the issue in my case. (Mainboard SN: 6050A2184601-MB-A02)
                          • Boardview and Schematic Bot
                            ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-12-2024, 03:36 PM
                            ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-12-2024, 03:30 PM
                            ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            ACER Aspire Aspire TC-886 Aspire TC i7-9700 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire TC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-886 boardview and Aspire Aspire TC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-12-2024, 03:28 PM
                            ACER Aspire Aspire TC-780 Aspire i5-7400 Specification for Upgrade or Repair
                            This specification for the ACER Aspire Aspire TC-780 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-780 boardview and Aspire Aspire TC-780 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
