Toshiba P20 graphics issue
+ More Options
Posts
  • stevo1210
    • Oct 2006
    • 4156
    A client of mine just sent me a message about her Toshiba P20 laptop. I have a similar one... the P25 so I know the thing inside and out.
    Anyway, this is what she wrote in a message to me.
    This laptop had a cracked screen originally, so I replaced this at considerable expense. Laptop worked for a while, then all of a sudden no image on the screen. I re-tested the screen & no problems there. The pc starts up & you can hear the XP operating system completing its configuration with its usual jingle. So, I started this up again & pressed F8 in safe mode & it does run in safe mode but with little lines on the screen & did have a binary code of zero's & ones before getting to the F8...( Best I can explain it ).
    I'm not sure where to even start with this one until I see it, but what do you guys think it is?
    I have a P25 with a faulty screen cable and goes fuzzy but unfuzzes when you move the screen or tap it. Sometimes it plays the retard game and the screen stays black but comes on after I press and unpress the switch that detects if the screen is closed or not... these sound kinda related?
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Toshiba P20 graphics issue
    I'm assuming the "binary code" was the bios?
    I doubt that helps but I don't know the answer :P
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Moved from General Computer discussion.
      sigpic
      (Insert witty quote here)
      • stevo1210
        • Oct 2006
        • 4156
        I was looking for my thread only to realise it had moved. I only noticed we had a notebook forum. Awesome!
        Anyway, can you guys help me out with my Toshiba P25 instead? Hard to explain, so watch the video please.
        http://www.youtube.com/watch?v=Y7UAx...Lr93P9lVHUBSFH
        • selldoor
          Slow Learner
          • 7870
          Hi Just a thought but the F8 key on my laptop is just above where the screen connector plugs into the motherboard. If the connector is not seated correctly pressing the F8 may be just enough to make a partial connection. It just being coincidence that it is in Safe mode.
          Try pressing F8 when ordinary windows is up and running, following the useful but annoying jingle.
          • stevo1210
            • Oct 2006
            • 4156
            I just tried that on the P25. No help
            • selldoor
              Slow Learner
              • 7870
              Hi - that was a suggestion for the p20.
              The p25, if youve not already tried - open it up and clean the contacts on both end of the screen cable. If it has a separate video card check that it is seated correctly. Clean the screen on off switch.
              What does it do with external monitor?
              If the p20 screen cable is the same try it on the p25.
              • stevo1210
                • Oct 2006
                • 4156
                Okay, got the P20 today. It's definitely a graphics card problem. I'm getting large blocky vertical lines that flash even when in the BIOS and also random artifacts.
                Since the owner doesn't want a new $250 motherboard, looks like I'll be swapping parts with my P25 then. This one even has a glossy LCD!
                • stevo1210
                  • Oct 2006
                  • 4156
                  Oh and can someone help me find a service manual for the Toshiba P20/P25? Thanks.
                  • selldoor
                    Slow Learner
                    • 7870
                    http://www.givemefile.net/smanuals/n...llite_p20.html
                    • mockingbird
                      • Dec 2008
                      • 5484
                      It _shouldn't_ be the GPU.... It has an FX 5200Go which wasn't known for failing...
                      This should also be a pre-ROHS laptop, so I'm stumped. Maybe it is the GPU.
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Yup its an FX5200 and definitely before ROHS, first ive ever seen like this too!
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Okay guys... some updates on the progress. Since the client decided that a new motherboard for her P20 (graphics inbuilt to board), she decided to buy a new Dell this time around. On the other hand, I stripped the P20 and took the whole LCD display (inverter and all) and also some plastics over to my P25... and it seems to have solved the no backlight issue! seems like an inverter or screen cable problem all these years.
                            Toshiba Satellite Pro 50-C-19L Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro 50-C-19L Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 50-C-19L boardview and 50-C-19L schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            09-06-2024, 07:00 AM
                            Toshiba Satellite Pro R50-E-13X Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Satellite Pro R50-E-13X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R50-E-13X boardview and R50-E-13X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-06-2024, 08:55 AM
                            Toshiba Tecra A50-EC-11Z Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Tecra A50-EC-11Z Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-EC-11Z boardview and A50-EC-11Z schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            09-06-2024, 09:00 AM
                            Toshiba Tecra A50-EC-13Q Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Tecra A50-EC-13Q Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-EC-13Q boardview and A50-EC-13Q schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                            Toshiba Tecra A50-EC-11E Notebook Specification for Upgrade or Repair
                            This specification for the Toshiba Tecra A50-EC-11E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A50-EC-11E boardview and A50-EC-11E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
