samsung s3510
  • scooby01
    • Dec 2011
    • 28
    samsung s3510
    Hi I have a customers samsung s3510 how has been using a universal maplins charger and has now no power. Now with an original charger their is a short on the mobo. I have tried 2 Chargers and the same things happen the led blinks on the charger and you can hear a pinking noise in the charger. It obviously has a short on the motherboard but I cannot find it.
    It has the power ic circuit near the battery, which is at the other end on the pcb and 1 power regulator gets red hot. I have changed that but still have th e same problem. Any help please.
  • scooby01
    • Dec 2011
    • 28
    Re: samsung s3510
    What can test and how.
    • b700029
      Banned
      • Sep 2010
      • 640
      Re: samsung s3510
      Post some pictures.
      • scooby01
        • Dec 2011
        • 28
        Re: samsung s3510
        There is a short and ic get very hot. marked.
        • dycc
          Vision
          • Nov 2011
          • 624
          • Côte d'Ivoire
          Re: samsung s3510
          the big cap is the problem below the processor on the other side of the board.
          you must replace it with 4 tantalum cap ( 2x470 ,2x330)
          i do not speak english very well . i am french man
          • dycc
            Vision
            • Nov 2011
            • 624
            • Côte d'Ivoire
            Re: samsung s3510
            the big cap (nec tokin oe687)
            • scooby01
              • Dec 2011
              • 28
              Re: samsung s3510
              can you point the 4 x small to with edit.
              I can see the tokin oe687 but cannot find where to buy it. any idea i am in th UK
              Thank you.
              • dycc
                Vision
                • Nov 2011
                • 624
                • Côte d'Ivoire
                Re: samsung s3510
                do something like that(attached file) . hope this help
                • dycc
                  Vision
                  • Nov 2011
                  • 624
                  • Côte d'Ivoire
                  Re: samsung s3510
                  you can find these caps on dead board if it is not possible for you to buy it
                  • dycc
                    Vision
                    • Nov 2011
                    • 624
                    • Côte d'Ivoire
                    Re: samsung s3510
                    arrangement with the capacitor:
                    (4x330e)or (4x330d) or (2x470e , 2x330e) or (2x470d , 2x330d) or (4x220e) or (4x220d)
                    e=2.5v d=4v you can also mix voltage values
                    • scooby01
                      • Dec 2011
                      • 28
                      Re: samsung s3510
                      I Get it now. In other words do not replace with nec tokin oe687, but use the 4 seperate ones in stead. Thanks Will give it ago. Got hundreds of old mobos. laying around,.
                      • scooby01
                        • Dec 2011
                        • 28
                        Re: samsung s3510
                        Hi I have completed the process by removing the oe687 and using 4 x 220d's but I am still get short circuit causing the chargers to blink. I am sure it was caused by a universal charger have you any other things ican try.
                        • Sparks88
                          • Sep 2011
                          • 110
                          Re: samsung s3510
                          check around power jack socket for shorts
                          • scooby01
                            • Dec 2011
                            • 28
                            Re: samsung s3510
                            There is nothing near the dc socket. It has 1 tiny capasitor then just tracking all the way to the battery/ power area i the other end of the board.
                              09-07-2024, 05:50 AM
                            • jesterace
                              Samsung UE46ES8000 Blown fuse but no other signs of short
                              by jesterace
                              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                              09-11-2024, 03:14 PM
                            • flat-earther
                              ASUS X54H laptop thinks it's always charging even with charger unplugged
                              by flat-earther
                              The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                              Windows also shows ''Plugged in'' when charger is not connected.
                              This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                              Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                              If I let battery run out and say it has 3% Windows will...
                              06-24-2025, 09:32 AM
                              09-06-2024, 11:40 PM
