Toshiba L40 weird touchpad problem
  • lew247
    • Jan 2012
    • 13
    I have a Toshiba L40-14l which is basically just a member of he L40 family
    I have this weird problem where the touchpad doesn't work properly
    It appears that the right button is stuck down.
    When I scroll across the screen using the touchpad its the same as using a mouse with the button held in.
    The left button clicks and shows as being clicked in the touchpad icon by the clock
    The right button shows as being held down.
    I have checked and I have the latest touchpad drivers installed.
    I've tried a usb mouse and this works perfectly, I'm guessing its something on the motherboard itself, maybe a cap? Hopefully fixable
    I have tried several things to try and fix this but none work,
    so far I've tried
    Changed the touchpad for a known good working one
    Checked the actual buttons and they work properly
    Changed the button board "just in case"
    Changed the touchpad cable
    Cleaned the contacts in the ribbon holder on the motherboard
    Cleaned the ribbon contacts itself.
    So I'm stuck, anyone got any ideas what it might be, or how to fix it?
    I'm hoping its something simple.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Toshiba L40 weird touchpad problem
    Tried booting a different OS (try a Linux liveCD)? This sounds like a software problem.
    • lew247
      • Jan 2012
      • 13
      forgot to say tried that already
      apart from putting a new blank drive in and installing a fresh copy of Windows, I also booted it from a Linux stick and it did the same thing.
      It's definitely hardware - unfortunately,
      • unveiled
        • Jul 2011
        hi you try to change the adapter if you have an extra because you adapter may be low in ampere because that is common in toshiba with low ampere
        • Sparks88
          • Sep 2011
          • 110
          boot into safe mode and see what happens then, check bios for any setttings for touchpad enable/disable, reset bios to defaults and see what happens, check ribbon connector on motherboard where its soldered to motherboard especially the ribbon clamp, check for continuity of ribbon cable and make sure the ribbon cable doesnt have shorts between tracks.
          • sebuncle
            • Jun 2010
            • 46
            • France
            hi i have same problem on vaio C and the problem was the adaptater.
            JOVY RE7500
            • delphi_firebird
              Toshiba Qosmio X755 Charging problem
              by delphi_firebird
              Hello Guys,
              I received Toshiba Qosmio X755 that has a charging problem and I'm stuck trying to figure out the problem.
              - When battery is unplugged i works without any problem.
              - When I plug in the battery after plugging in the charger, it works correctly and the battery is charging.
              - When I plug in the charger after inserting the battery, it stops working. ( voltage dropped and consumed 8A, reaching the maximum capacity of my bench power supply for 5 seconds, and stop working after )
              Can you help me diagnose the problem? I have attached...
              10-16-2023, 03:04 AM
              09-06-2024, 05:59 AM
              Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
              This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
              09-06-2024, 05:33 AM
