I have a toshiba satellite a215 laptop. When i turn it on, it boots up normally, but the screen is blank. No picture, no backlight, nothing. I know it isn't a hardware problem cuz i have seen the screen work, it actually turned on one day about a month ago and i watched it boot up successfully. I left it on for a couple hours with know problems, turned it back off. I went to turn it back on and the screen was right back where it was before, blank. Some help with this would be appreciated.
Toshiba Satellite a215 blank screen
Re: Toshiba Satellite a215 blank screen
Sounds Like the LCD may have gone out on you. Try plugging the laptop into an external Monitor and see what you get. You might also have to hold down the FN key and one of the Function keys. The one with the picture of an external monitor on it.
If the LCD is bad they can be had on ebay for a reasonable price in most cases. -
Is usually not the LCD itself but the CCFL tubes or the Inverter.
If an external monitor doesn't work you have other problems.
Maybe a bad GPU or the switch that cuts out the monitor out when you close the lid is stuck.
.Mann-Made Global Warming.
- Dr Seuss
i have narrowed it down to the gpu. Could it just be that the solder is not connecting right anymore? Is it possible to fix it? How do i test if gpu is still good? I really just want this laptop to work. It is too nice to just throw away.Comment
I don't know on that model.
If it's removable you can replace it.
If it's not you can try a reflow but you'll probably end up needing a new mobo because that's hard, tricky, and often doesn't work.
- Dr Seuss
Congrats.
If you are lucky it will last a while, doesn't always.
- Dr Seuss
