Help Identifing the fuse
  • fasner
    • Sep 2011
    • 15
    I am trying to get this power supply working again and I need to know if there is a fuse on this circuit board. Can someone help with this or what symbol for the fuse am I looking for. I replaced most of the caps already. Thank you
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Help Identifing the fuse
    This looks like a LCD power/inverter board and thus should be in the display troubleshooting section.
    The fuse is the red circle blob next to the AC input. Fuses are usually marked with a "F" on the PCB. For example, F100. A good fuse should measure less than 1.0 ohms on your multimeter.
    --- begin sig file ---
    --- end sig file ---
    • fasner
      • Sep 2011
      • 15
      Thank you for the response. It is reading .2 ohms. This is the Power PCB for a Samsung Sync Master 914V LCD. I changed most of the caps but still cannot get a good signal on the LCD. It started by losing any screen after about 1 minute. Thought I would strart by swapping out most of the caps--still not video, just straight vertical lines on the LCD.
      • retiredcaps
        • Apr 2010
        • 9271
        • retiredcaps
          • Apr 2010
          • 9271
          Ask the moderators to move this thread to the troubleshooting computer display section so experts like PlainBill, Alexanna, jetadm123 can add their input.
          If you are not getting video, measure the DC voltage on the voltage regulators on the logic card and measure the DC voltage on the connectors between the logic and power board.
          Also, keep all your responses and posts/per monitor in ONE thread. Otherwise people will get easily confused and ignore your requests.
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • jesterace
            Samsung UE46ES8000 Blown fuse but no other signs of short
            by jesterace
            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
            09-11-2024, 03:14 PM
          • jshhh
            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
            by jshhh
            Hi guys,
            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
            Anybody know how to remove this type of fuse?
            (The fuse is toward the bottom of the image labeled F2)...
            06-17-2025, 01:35 AM
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
