Dell XPS M1530 not taking start
  • hpmah21
    • Aug 2011
    I am using XPS M1530 since from last 3 yrs 8 months. Day before yesterday, I have safely shut down the system, inserted a battery. yesterday when I tried to start up my system, it was not getting on. I found there is no LED glowing on the laptop. I tried it from battery but no change in the status.
    On AC adapter, the LED light was glowing and it remains on evenafter connected to laptop.
    if the fault is in motherboard then what probably the fault, as I think it may be the DC to DC converter. I have yet not checked the motherboard.
    It has nVidia on board...
    Please help me on the same .....
    have a great day to all of you
  • scobie_21
    • Jul 2011
    • 144
    Re: Dell XPS M1530 not taking start
    More than likely the GPU needs to be reballed or less permanent reflow'd. I have seen this before on this model.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Dell XPS M1530 Laptop Schematic
      07212-1 07211-2...
      10-11-2024, 06:43 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
