Re: Medion MD42200 does not power up
Try checking for shorts in other mosfets and capacitors (use your continuity test). From here, it gets tricky. In most modern boards, it's virtually impossible to manually trace a voltage rail across the laptop. Maybe someone else here can chime in but I think your best bet here is the trial and error approach. Test the larger ceramic caps and other 8 pin mosfets. Some will be dual channel which are a little more tricky to test so for the time being stick with the single channel ones (you can tell since they have 4 drains in parallel and 3 source pins in parallel). Sometimes caps will have visible damage (they crack and shatter so often times they'll look like an egg shell crack). Good luck!
