acer 5920 g blinking power adapter
  • caprajaya
    replied
    Re: acer 5920 g blinking power adapter
    i have the same problem on my acer aspire 4349. indicator lamp at the charger suddenly ded. can anyone help me
  • Shamel
    replied
    Originally posted by ablacon64
    Check capacitors PC112 and PC118 near the memory slots. One of them (or both) may be shorted. Very common on that model.
    Thank you so much for the useful post now my laptop is working again after 3 years
  • kabukabu
    replied
    Thank you guys. I desoldered PC112 and PC118 and laptop is working now. I wont even bother replacing them............... xD
  • eniac22
    replied
    I have the same problem but was made a mistake and tested with universal charger and then the PU9 burnout.
    I have change it (PU9) with new and also have remove and test the PC112, PC118, PC90, PC74 and PC24.
    The capacitor have the correct capacitance but can be sorted and have the correct capacitance ?
  • Ramee
    replied
    If you change ampere with this one.
    http://www.aliexpress.com/item/Frees...040084547.html
  • dj_ricoh
    replied
    Originally posted by dellxps15
    if u cant change ampere, change it. it is broken i suppose.
    i was noob and now its late to change it
  • dellxps15
    replied
  • dj_ricoh
    replied
    yeeee NO!
    can`t adjust the Amps
    i saw something made in germany but its only 15v and 2amps but ... you know made in germany
  • dellxps15
    replied
    is your working fine ?
    i told you they are all coned... and varios name rebrand
  • dj_ricoh
    replied
    im going to buy this lab psu:
    http://www.ebay.it/itm/360687892687?...84.m1427.l2649
    send the 52+7€ approval. if seller accept it will be mine
    looks like this lab psu is the most cloned on internet. they are all almost the same
    i got the same! OMG other name though maybe same crap inside
  • dellxps15
    replied
  • dj_ricoh
    replied
    A quick way to test for shorted components on the main power rail is to connect a lab power supply to the charger jack and increase voltage until current is around 2A. Leave for a minute or so and feel the parts on the board will your finger - something will be getting hot.
    i got a cheap crap bollox psu that looks like you can adjust but i can`t it just show how much it takes sad day; dooow i did learn stuff with it!
  • artois7
    replied
    It was PC112 - replaced with a similar cap (didn't have exact value so took off scrap board) and all is well. Thank you!
  • Th3_uN1Qu3
    replied
  • artois7
    replied
    Just about to try and tackle this but can't find said capacitors - anyone have a picture with them highlighted?
  • awadesh15
    replied
    Does the LCD lamp works?
    Try to press fn+F5 to switch to external monitor.
    Hai, it seems u r much qualified, pl help me to sort out my problm.i hv acer 5920g, it got nvidea p407 failed last year, it repaird by rebolling and I used it 1 more year.now it again failed and no more reballing was successful. It was nvidea p406 ver 1.3.so I bought old working p407 but with ver 1.5 .tested on other notebook working.ok.i fit on my acer 5920g buy it takes 6 restarts to no video at all..I later noted that modem is missing. I tried without modem to external monitor no result.fn+5 no result..connected tv too still no result I got only white screen.i resembled after dissembling..backgroud I hear w7 welcome sound and alt+f4 enter shut it correctly.
    1.can acer 5920g give video output without modem..I hv missing. ?
    2.6 times restarts do not bother me..is new video card I bought p407 ver1.5(previous I hd ver 1.3).no compatible..it does not give video too..
    Any help greatly appreciated. Thx
  • MORPHOGEN
    replied
    Thanks ill just searching for more posts on it.
  • dellxps15
    replied
    buy a cheap multimeter. there is already a thread of possible acer 5920g capacitors that can be fault. just put in diode mode. mainboard withoud any power. black to a metal spot. the red to each side of a cap. if bot side are shorted, try remove it and see if short is cone.
    best to start from coils however.
  • MORPHOGEN
    replied
    My replacememt laptop i bought arrived today i tried too get the same model n number as the one that has the blinking led power supply problem, so if i took my drive from mine and fit it in this other one would it work okay? As i have a few dj comps comimg up and dont have the tools too fix my brokem one just now. Not sure if there might be a few problems with drivers n registry's and boot. Any tips?
  • MORPHOGEN
    replied
    Ive got this problem too my mate a dad did fix it something with the power supply. Was running fine then went off after a month or so of working fine again. Took it too a diff guy he said i need a new motherboard but have no idea on his knowledge of computers i mean if it was just bad caps why didnt he try replace them? So i would like too test them myself on my acer 5920g. What machine do i need am esr metre for around 80£? Ive also bought a same spec and model number laptop as the one im using too try n swap the drives over if i cannot fix mine. But hopefully i can fix mine. Im not good at soldering but my friends dad could do that as he did own his own repair shop.
