Mercury Green550 Dead
  • nbanti
    • 56
    Hi dear all,
    I have Mercury Green550 Laptop dead. When it is working i have serviced it. because of Ants . When after service, i have plug the laptop keyboard to the main board. That laptop is pluged to power adapter and battery is charging. After pluging the keyboard i have turn on the laptop. It is power on but only for 3-4 seconds. after that it gos off. Now it is not powering on and LED's are still off. Please tell me what i have to do. Please.....
  • mockingbird
    • Dec 2008
    • 5484
    Re: Mercury Green550 Dead
    I think we need some sort of scientist in here to unscramble your sentences for us.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      I think he meant the following:
      He took his laptop apart because ANTS, as in real live insects, got into it. Now when he put it back together it doesn't work anymore.
      Check all the ribbon cables, make sure you haven't broken any of them. If the cables are okay and there seems to be nothing else wrong with it i'd just get another laptop, that one is too old to be worth any time-consuming repair.
      A working TV? How boring!
      • Scenic
        o.O
        • Sep 2007
        • 2642
        firstly.. what the hell rode them into naming a Pentium 4 notebook as "green" !?
        secondly, it's most likely a rebadged ECS Notebook, ie: garbage to begin with.
        Mercury G550
        http://www.mercury-pc.com/product-de...productid=373#
        ECS G550
        http://www.ecs.com.tw/ECSWebSite/Pro...#fragment-SPEC
        i keep stumbling over dead ECS notebooks on ebay a lot.. and the G550/Green 550 is one of the most common models. that's why i immediately thought about comparing this. sure enough.. looks like a simple rebadge..
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          ECS OEM'd a lot of stuff for Mercury. I had a Mercury motherboard a while back, and sure enough, it quickly traced down to ECS. The board was half-decent tho, but it was back in the Socket A days.
          • max-power
            Dell E6540 laptop completely dead after dssasembly
            by max-power
            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
            03-24-2025, 08:49 AM
            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
            09-06-2024, 09:30 PM
            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 08:47 AM
          • RdeveLabs
            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
            by RdeveLabs
            To all the members here...
            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
            05-05-2025, 04:59 AM
          • Loli Popu
            DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
            by Loli Popu
            Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
            12-13-2024, 03:28 AM
