Acer Aspire 5672WLMi fails to power up
  • rize
    • Jan 2011
    This laptop was used with the wrong AC adapter. Original AC adapter is lost. I tried powering up with bench PSU with 19 V DC but it was no go. The laptop was drawing something around .20 amps when I pressed the power reset which is obviously not enough to get anything going, no lights, no sound - no nothing.
    On eBay I've seen the power jack and cable that plugs into the main board sold as a unit. Is it possible this jack & harness assembly has a power fuse included which may have burned out when a wrong AC adapter was used?
    Any suggestions on how to trace the burned out components? Possibly the power regulation section of the main board, somewhere underneath the power-jack. I received one helpful tip to look for burned out diodes in this area.
    Anyone with information on the strip-down sequence of the main board, in case I buy a refurbished replacement board.
    Thank you for your comments in advance.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Acer Aspire 5672WLMi fails to power up
    Regarding the Acer power jacks... I just worked on an Aspire 5513... To my best recollection, there was no fuse in that cable that connected the jack to the motherboard.
    • rize
      • Jan 2011
      Thank you for posting. I just got a new AC adapter which is suppose to be an OEM part, hooked things up and as I expected pressing power reset did not produce any results - no lights, no fan - nothing but silence. I checked the voltage on the adapter which was 19 VDC. I started removing screws to expose the board as much as possible but got stuck after removing all the screws from the bottom of the chassis and back of the LCD lid. I'm not sure how to remove the keyboard and disconnect the LCD panel. I've removed few easy to get items like the battery, hard disk and can certainly get to the fan and the copper pipe cooling assembly. There are obviously some hidden screws holding the top chassis cover. Any ideas on how to remove the main board will be very helpful.
      Thanks for all your comments.
      • mockingbird
        • Dec 2008
        • 5484
        If you look at my post about the 5513 here, someone answered that it is possible that when I corrupted the bios on the laptop, it can actually corrupt an integral part which allows power to flow through the motherboard. I never thought I'd encounter something like that, but indeed, after the bios flash failed, I had similar symptops to yours. Acer boards have an SOIC 8-pin BIOS (At least mine did), so it would be relatively trivial for me to unsolder it and get it reflashed.
        The problem is, I don't know if that would solve it, it could be there's another chip that was corrupted by the flash.
        In any case, I found a website that has a service:
        http://www.bios-service-center.com/p...oducts_id=6278
        I just ended up getting a new motherboard for $100. Sure, it was expensive, but worth it for an X3100 laptop.
        • zedok
          • Feb 2011
          Hi!
          I have an acer 5672 wlmi notebook, my friend had reball / BGA the vga and then we need to change the fan, but we don't have a same type, so we take out and take in an another. Now, the computer is doesn't start. no led no fan. sometimes the led is on for a sec. Could we do something to get it to work or it can goes to trash?
          • Scenic
            o.O
            • Sep 2007
            • 2642
            wrong pinout on the fan, creating a short?
            • zedok
              • Feb 2011
              I dunno, but the fan has the same output volt etc. But it is interesting that, we did it 3-4 days ago. And the laptop didn't start only from yestarday :S
                ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                09-12-2024, 03:28 PM
                ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                09-06-2024, 05:27 AM
              • DenK
                Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                by DenK
                Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                12-06-2024, 01:29 AM
              • Bonaventure Vigil
                ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                by Bonaventure Vigil
                Dear All,
                Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                12-12-2024, 10:22 AM
