iPad 6 A1954 SWAP
+ More Options
Posts
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    iPad 6 A1954 SWAP
    Hi all. I need advice on transferring the main chips to the iPad 6 a1954. What chips are required to be transferred to the donor board?
  • PITERPENY
    • Jul 2023
    • 455
    • Ukraine
    Re: iPad 6 A1954 SWAP
    is it enough to transfer?
    U0700 processor
    U8100 power supply
    U7500 wifi
    U0601nand
    NFC
    U_BB_RF
    Maybe what is not needed or what is missing?
    • elecsoluces
      • May 2020
      • 66
      • France
      You forget CPU eeprom U1101.
      I don't think you need to swap U8100.
      • elecsoluces
        • May 2020
        • 66
        • France
        If your Ipad has a sim card reader you need to transfer baseband eeprom too.
        • PITERPENY
          • Jul 2023
          • 455
          • Ukraine
          Yes, I have an iPad 6 LTE. Can you please tell me how it is indicated on the diagram? And is it possible not to move the processor or is it necessary? I'm also interested in whether it is necessary to transfer the U_BB_RF chip?
          • PITERPENY
            • Jul 2023
            • 455
            • Ukraine
            the mission failed; after dismantling the processor, several legs are missing.
            • GeirAndersen
              iPad .pcb file collection
              by GeirAndersen
              I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
              Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
              IPAD COLLECTION 1
              +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
              +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
              +---iPad mini3 820-00008(A1599) 820-00002(A1600)
              +---iPad mini4 820-00180(A1538) 820-00177(A1550)
              +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
              +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
              12-09-2024, 09:28 AM
            • ugamazing
              Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
              by ugamazing
              I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
              08-31-2022, 07:34 AM
            • grimacelord
              Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
              by grimacelord
              Hello.
              Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
              If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
              For example, when I connect the iPad to...
              04-15-2022, 11:06 AM
            • trepachka
              iPad Air A1475 Boot loops after replacing battery
              by trepachka
              This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
              The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
              I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
              11-08-2024, 03:17 PM
            • feherhollo
              WSON8 NEW Bios Chips READ, ERROR, ETC.
              by feherhollo
              I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
              I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
              For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
              11-26-2023, 09:33 AM
