I have a laptop with a gtx 1070. It has had issues for a long time due to the micron memory, basically when the voltage drops to 0.8v the memory can't switch fast enough and the laptop crashes constantly. It is a known issue with these cards. I used pascal tdp tweaker and tried flashing the bios, The black ch341a reads and flashes ok, but it fails to verify every time and now the laptop doesn't boot at all. I used a high power fast charge port on my computer and it still won't work properly. I'm not sure what I'm doing wrong as I just bought the programmer
Laptop gtx 1070 bios flash fail
by BloodhoundjeHi everyone,
I have desoldered the bios chip (GigaDevice...-
Channel: BIOS Requests ONLY!
by thxd43Hello, first of all, excuse me, I am using the translator, English is not my native language.
I have a Lenovo ideapad 330S - 14IKB laptop.
The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a... -
I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
Why I am pretty sure I need this to repair?
1) Power supplies seem OK.
2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by AquaMan UaHello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...2 Photos
- Loading...
