Lenovo ThinkPad T430 - LCD replacement - only white screen.
  • bpjl
    • Jun 2016
    • 28
    • Polska
    I've got a Lenovo ThinkPad T430 laptop with a broken screen and a problem with the backlight.
    I replaced the broken LCD B140XTN03.1 with LTN140AT28. Everythings should bo OK. However, when turned on, the screen only lights up in white. On the external monitor, the system loads and the computer works normally.
    I will mention, that while the system is loading, the LCD blink black once - probably when the graphics driver is loaded. Backlight brightness adjustment works normally.
    Is there something I can check on the motherboard or is it a defective matrix and should I exchange it at the seller for another one?
    Or maybe the screen ribbon cable?
  • rddube
    Aspiring Expert
    • Jun 2013
    • 954
    Re: Lenovo ThinkPad T430 - LCD replacement - only white screen.
    Both questions you ask (defective matrix ? ribbon cable?) are probably close, but first I would like to see a very close photo of your connection to the LCD, probably not seated properly. A microscopic photo would be nice, but if you can't do that, inspect it with a jeweler's loupe and make sure it is seated properly and not damaged when you inserted it.
    • bpjl
      • Jun 2016
      • 28
      • Polska
      I checked the connection several times. Everything looks good. I decided to measure the voltages at the screen connector on the laptop motherboard (Lenovo T430 NZM4I-7 UMA VILT3 NM-A082):
      PIN 2,3,4 - VCC3P = 0V
      PIN 5 - VCC3B = 3.3V
      PIN 30 - VCC3P = 2.88V
      PIN 35,36,37,38 - VBL20 = 19.9V
      Following the missing voltage on pins 2-4, it turned out that on one side of fuse F3 I have 3.3V and on the other side 0V.
      After the test short circuit, the screen start working.
      I replaced fuse F3 and the problem was solved.
      • rddube
        Aspiring Expert
        • Jun 2013
        • 954
        Good job. Glad to hear you solved it!
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • BMCappelletti
          Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
          by BMCappelletti
          Hi everyone.
          Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
          Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
          Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
          02-18-2025, 12:22 PM
        • kino0924
          Screen Replacement for A2337
          by kino0924
          I have a 2020 macbook air m1 that needs a screen replacement (cracked)
          Right now, I have few options but not sure what to take
          1. Screen only from aliexpress (80 USD)
          2. Housing and screen from aliexpress (144 USD)
          3. Genuine used screen from ebay (250 USD ish)
          4. New screen from ifixit (450 USD)
          To be honest, I dont think new screen from ifixit is worth it since I can get it replaced by apple with same amount of price (haha)
          Now, I am wondering is it really worth to spend 100 more on used genuine screen....
          01-19-2023, 02:02 PM
