Case of study - Lenovo Legion Y530-15ICH
  • alex92ayfer
    Alex
    • 8
    • Granada
    Hi all!
    I am self-taught in motherboard repair and I find myself somewhat lost.
    Motherboard name: NM-B701
    The info that i have:
    The board arrived with a short on the 3VALW line (0.2ohms). I take out the coil and the short is on both sides. I remove the 3VALW AND 5VALW controller (RT6585) and now I only have short on the load side. I inject voltage (2v) into the 3VALW line and with the thermal camera the PCH heats up in one corner. I take it out and now 3VALW is at 270ohms. I inject 3v again and now the EC heats up. I remove it and short is gone (line go the k range in ohms), reprogram BIOS, EC and change the PCH.
    And this is how I am now:
    The motherboard connected to the lab PSU, take 0.01/0.02A and go something like 0.28/0.30A to end at 0.4A and drop at 0.01/0.02A... Sometimes this in a loop, sometimes this is only one time and you need to press the power button again.
    So maybe you have a problem in vs voltages... i think..
    And this is where it gets complicated for me...
    With the oscilloscope:
    Channel 1 - YELLOW - 3VS
    Channel 2 - BLUE - 5VS
    And i can find any shortcircuit or low resistance on the motherboar...
    I don't have VCCCPUCORE. The VCCCPUCORE rail resistance is 2.1Ohms
    NVVDD is present and the rail resistance is 0.6ohms...
    Any advice on where to go next? I'm kind of lost.
    I already removed the audio IC and the network IC, just in case they were causing problems... but no difference
    Thanks for you time.
    Link to schematic - https://www.badcaps.net/forum/showthread.php?t=90257
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
  • tomodachi
    • Apr 2012
    • 602
    • Turkey
    Re: Case of study - Lenovo Legion Y530-15ICH
    Did you try with original charger ? Since EC was also damaged there could be some issue along the adapter ID pin, check that too
    • reformatt
      • Feb 2020
      • 1414
      I would normally write something like this off. Likely had overvoltage on both 3V and 5V rails so you can't trust that any IC on those rails survived. Where did you source the PCH from?
      • alex92ayfer
        Alex
        • 8
        • Granada
        Hi to all. First at all, thanks!
        I try with the original charger, with the same result. And to use the lab power supply i put a resistor (1.2K) in paralel, from ID to GROUND (see it in a forum) to simulate a 130W charger. Same result withouth the resistor.
        Ill go to check ID pin. I should have a comunication, right?
        I know... the 3v low side mosfet was burned. Well no mosfet in there.... just a hole. I needed to rebuild the track from his gate and now i have 3 and 5 volts. The PCH is from Aliexpress. From SUHMS seller...
        • reformatt
          • Feb 2020
          • 1414
          Even though I use SUHMS myself, I wouldn't trust a PCH from China. They're usually pulled off dead boards and not new. Check Sorin's Electronic Repair School YT channel and what he says on PCH's from China....
          Last one he got that worked was from Europe I think. All the China ones he's tried simply don't work.
          • piernov
            • Jan 2016
            • 4435
            • France
            Used PCH may have Boot Guard enabled.
            • alex92ayfer
              Alex
              • 8
              • Granada
              I saw it! I have been a follower of the channel for a long time. I know, it's a lottery... sometimes I have bought bga as a cpu for example... and it worked correctly. But I don't think this one... The pch has a crystal (YH2) that is not oscillating when the machine tries to start.
              Although I am a newbie with the oscilloscope and I don't know if I will have it correctly configured to measure crytal.
              I'm thinking about re-soldering it. With new balls
              • alex92ayfer
                Alex
                • 8
                • Granada
                YES xD but they sell it like original, NEW 100% tested no fake...
                I ordered another one. Germany, elecronicloop.
                • alex92ayfer
                  Alex
                  • 8
                  • Granada
                  Hi to all. The machine is working after reflow the PCH. So my rework process was not well adjusted.
                  All working fine... BUT when the GPU install the drivers on windows, after some minutes, seconds (random time), the laptop lose the image and frozen.
                  Having to turn off the machine while leaving the button pressed. When booting and logging in, it loses the image again and freezes.
                  That's why I think I now have a VRAM or GPU problem. Is MATS compatible with laptop GPUs? Or, it only working with desktop GPU
                  Thank for all.
                    Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                    This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 05:00 AM
                    Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                    This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                    This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-07-2024, 04:10 AM
                  • mon2
                    A2141 Not powering on - case study
                    by mon2
                    This is a case study on a 'sudden death' A2141 unit brought in for service.
                    USB-C meter is @ 5v with ~0A current draw.
                    a) Disconnected battery. No power to the machine. Applied the Qianli Tail tester with the USB-C connector. Each USB-C power connector was green with the diode mode of testing. CD321x are not defective as originally thought.
                    b) PPBUS_g3h is not shorted but is a low voltage due to the low INPUT voltage of 5v being boosted. On a random power up attempt, PPBUS_g3h was at the expected 12v63 range AND input voltage was observed to be @ 20v for...
                    07-10-2025, 10:58 AM
                    LENOVO Legion Y720 Legion 1800x Specification for Upgrade or Repair
                    This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                    09-12-2024, 02:30 PM
