Asus G512LI main board R 2.0 will not power on ?
  • ub6ib969
    • Jul 2010
    • 198
    hi,
    any assist will be a great help.
    Asus G512LI main board R 2.0 Unit does on power, I suspected power mosfets. However missing power to P_CHG_ACMOS_S_ 20 line. Q8901 does have 19.8V at the source. A/D_DOCK_IN is located at PC8915 (pin1) but missing P_CHG_ACMOS_S_ 20 at pin 2.
    I do have schematics and boardview if needed.
  • mon2
    • Dec 2019
    • 14040
    Re: Asus G512LI main board R 2.0 will not power on ?
    See attached.
    The 2*DCin mosfets are N-channel. Each requires the GATE pin # 2 on these parts to be higher than the voltage being passed between source / drain pins.
    Often, the gate voltage should be ~25 volts to enable these N-channel mosfets.
    The voltage is driven by the ACDRV pin on PU8900 (Charger IC) = adapter voltage + REGN voltage = boosted voltage for gate drive.
    As per the sticky article by @Piernov (see above - a must read) - the 2nd DCin mosfet will often become defective and cause the gate voltage to tank.
    Start with carefully fluxing and removing resistor @ PR8918. This will isolate the ACDRV pin and the DCin mosfets.
    Then power up again. Carefully measure the voltage to ground on the removed PR8918. Interested in the ACDRV pin voltage to ground.
    Is it now ~25 volts?
    If not, continue to measure the voltage to ground of:
    REGN
    CMSRC
    VCC
    on the charger IC.
    • ub6ib969
      • Jul 2010
      • 198
      Originally posted by mon2
      See attached.
      REGN
      CMSRC
      VCC
      on the charger IC.
      thank you for your help. I removed PR8918.
      Pin1 CHG_ACMOS_G_20 0.0v
      Pin2 P_CHG_ACDRV_20 0.0V
      P_CHG_VCC_R_30 19.3V
      P_CHG_VCC_30 17.5V
      • mon2
        • Dec 2019
        • 14040
        P_CHG_VCC_30 17.5V
        This is too much of a voltage drop.
        Check the resistor @ PR8916 = 4R7. Confirm the resistance value.
        Also check the resistance to ground of P_CHG_VCC_30.
        No power to the board when checking resistance.
        Remove the battery as well to confirm this Vcc voltage. It should be very close to the source adapter voltage.
        PC8914 is also a suspect due to this voltage drop.
        • ub6ib969
          • Jul 2010
          • 198
          resistance mode
          PR8916 Value = 0.071-0.080
          ground probe on ground, and red probe to test.
          P_CHG_VCC_30= .0L
          VCC=19.2v
          PC8914 =19.2V
          pin 1 resistance= 0.584 (red on ground and black on pin 1)
          • mon2
            • Dec 2019
            • 14040
            ?? Select the lowest resistance scale on your meter. Then test again.
            The resistance should be around 5 ohms. In your post, do note the units of measure (ie. ohms, volts, etc.). Otherwise, take a picture of the meter face for a review.
            • ub6ib969
              • Jul 2010
              • 198
              Sorry it was V not in ohms
              • ub6ib969
                • Jul 2010
                • 198
                PR8916 = 0.588V on pin 2, pin 1 0.646V in resistance mode ( red probe ground and black probe), once I select the 200ohm range my measurement is 194.4 ohm
                • ub6ib969
                  • Jul 2010
                  • 198
                  update:
                  replaced pr8916 = 4R7 with 5ohm however still getting 0.0 V @ CHG_ACMOS_G_20
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • JDC
                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                    by JDC
                    ONN 100012588
                    Issue: No Power, Then Rebooting After Main Board Change
                    Short answer: replace main board and power board
                    Technical answer: replace main board and Q306 & Q307 on power board.
                    Long answer:
                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                    07-15-2022, 07:39 AM
                  • Destroyer-Br
                    [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                    by Destroyer-Br
                    I'm working on an Acer Nitro 5 unit with the following specs:
                    • Motherboard: LA-J871P Rev: 1B
                    • Model: Acer AN515-55-59MT
                    • S/N: NHQ7JAL00403906A973400
                    • SNID: 03902728734
                    Initial Issue
                    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                    04-17-2025, 08:18 PM
                  • cheeky2
                    by cheeky2
                    05-25-2024, 03:27 AM
