Lenovo ThinkPad E14 Gen 2 / GE4B0 / Not Charging
  • Ado02
    • Jul 2021
    • 100
    • United Kingdom
    I am currently working on the Lenovo ThinkPad E14 Gen 2 with a GE4B0 motherboard.
    Issue: The laptop runs on battery power, but it fails to recognize the charger. The LED1 indicator does not illuminate in white or orange when the charger is connected.
    My investigation:
    1. LB4709 and LB4708 both register 20V.
    2. UE1:
    Pin 34 ACIN_LED measures 0V at R31.
    Pin 11 VCC_LPC_ESPI registers 0.27V.
    3. +3VL_EC at R42532 and various other locations, following the schematics, measures 1.7V.
    Charging IC: BQ25710
    Measurements without battery connected only charger.
    The Boardview and Schematics are attached. But from very similar boards.
    MOD Edit - Link to Schematic https://www.badcaps.net/forum/showth...hlight=NM-D011
    Reminder: rules and organization of this section https://www.badcaps.net/forum/showthread.php?t=117483
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo ThinkPad E14 Gen 2 / GE4B0 / Not Charging
    What voltage do you have PU3 pin 15 ? PJ3/PJ4 ?
    • Ado02
      • Jul 2021
      • 100
      • United Kingdom
      0v at RE135 (no component attached to these pads). I also did a check on Pin 15, but due to spacing I couldn't be sure - 0v
      • Ado02
        • Jul 2021
        • 100
        • United Kingdom
        I just tested the same things on a working motherboard. On this one, it turns on when the charger is plugged in, but the power/charger LED doesn't light up. So, I assume the LED doesn't work when the charger is connected. Can someone confirm this?
        Here are the results of my tests:
        LB4709 and LB4708 both show 20V.
        UE1:
        Pin 34 (ACIN_LED) reads 0V at R31.
        Pin 11 (VCC_LPC_ESPI) is at 1.8V.
        Pin 15 is at 3.35V.
        +3VL_EC at R42532 and various other spots, as per the schematics, measures 3.3V.
        • Techtiger
          • Oct 2014
          • 1602
          • france
          didn't ask you to test RE135 signal. This is an input signal for the last stage of the power sequence. PJ3 is a test pad to check if your +3VALW is working or not, and PJ4 is a test pad to check if your +5VALW is working or not
          • Techtiger
            • Oct 2014
            • 1602
            • france
            if PU3 TPS5139RJER is not producing LDO voltage on pin 15 (0V), then test the supply for the IC on any of pins 2, 3, 4, or 5
            • Techtiger
              • Oct 2014
              • 1602
              • france
              What voltage do you get on PL4, PQ4, any pin 2, 3, 4, or 10? let us know
              • Ado02
                • Jul 2021
                • 100
                • United Kingdom
                Faulty Motherboard PJ3 1.8V and PJ4 0v
                On Working Motherboard: PJ3 3.36v and PJ4 5v
                • Ado02
                  • Jul 2021
                  • 100
                  • United Kingdom
                  Faulty Motherboard:
                  1 - 1.58v
                  2 to 5 - 1.5v
                  1 - 8v
                  2 to 5 - 9.24v
                  • Ado02
                    • Jul 2021
                    • 100
                    • United Kingdom
                    Faulty Motherboard
                    PQ4 2 to 4 - 1.50v
                    PL4 - 0v
                    PQ4 2 to 4 - 9.24v
                    PL4 - 9.28v
                    • Ado02
                      • Jul 2021
                      • 100
                      • United Kingdom
                      I think the VINT20_IN is missing.
                      F6101 1.5V is going up and down a little. If I am correct this should be 20V
                      • mon2
                        • Dec 2019
                        • 14203
                        Check the voltage to ground on each side of the fuse F6101. Is it stable on one side?
                        • Ado02
                          • Jul 2021
                          • 100
                          • United Kingdom
                          Both sides go from 1.4v to 2.5v
                          • mon2
                            • Dec 2019
                            • 14203
                            It is too low. Remove all power. Meter in resistance mode.
                            Measure the resistance to ground on each side of this fuse. Post each measurement.
                            • Ado02
                              • Jul 2021
                              • 100
                              • United Kingdom
                              I am unsure if I am doing something wrong, but the values consistently move on the faulty and working motherboard. But they always seem to be in the 1.200 Milliohms region but never stop moving.
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                Follow simple basics:
                                01.Check resistance between
                                Source-Gate
                                Source-Drain
                                Gate-Drain
                                of both N-fets PB5/6
                                • Ado02
                                  • Jul 2021
                                  • 100
                                  • United Kingdom
                                  QB6
                                  1-2-3 & 5-6-7-8 / 3.67 Mohms
                                  1-2-4 & 4 / 4.00 Mohms
                                  4 & 5-6-7-8 / At this point I noticed that the MOSFET started to lift away from the motherboard. So, I can only think it's shorted, and the solder has given way.
                                  It's an E120GN Mosfet - I have a few other Lenovo motherboards around like 17812-1 - but I can't seem to find the same one. Any suggestions?
                                  • Ado02
                                    • Jul 2021
                                    • 100
                                    • United Kingdom
                                    Solved:
                                    Replaced QB6 AON7466 - found the same mosfet on another Lenovo motherboard and the charging is restored.
                                    Thank you for your help...
                                    • trufoldino157
                                      • Aug 2020
                                      • 19
                                      • Russia
                                      Solved:
                                      Thank you very much for your help, everything worked out. Respect.
                                      SUPEREXTRAMEGATURBOULTRA:радуйся:
                                      • reformatt
                                        • Feb 2020
                                        • 1411
                                        Same fault on this model here today. Voltage from QB5 was stable at 19.5V, but output of QB6 varying up and down. TBTA_GATE_VSYS was fluctuating proportionally. No shorts found etc. The FET measured ok, was easier to change that than the USB C controller UB7. The IC came away very easily from the board, as mentioned earlier in this thread. Looks to either had inadequate paste from the factory or just got really hot. I didn't have a AON7466 to hand, but an AON7402 was the same spec and worked fine.
                                        Looks to be a stock fault. Money for jam.
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
