hp la-h461p no power
  • ahmarzo
    • Mar 2015
    • 171
    • india
    have hp la-h461p with no power on and no light on dc lack .by tracing the problem found +3vl shorted to ground and the i/o ic kb9542q was shorted after replacing it the shorting is removed and still no power on dc jack.pu 301 has 19v on pin 2-5 and 4v on pin 11 .do i have to program this ic for power on .have changed pu301 but same problem plz help.https://www.badcaps.net/forum/attach...9&d=1690900091
    this is schematic link
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp la-h461p no power
    KB9542 is programmable,so yes it has to be programmed. My experience with this particular KBC is not good. Most of them sold as new are defectives and to top it all it often ends in verification failure while programming it. on some boards, has to replace 3 KBC in a row to fix it.That makes it pretty unviable as customer dont want to pay much and results in loss to technicians like us.
    • ahmarzo
      • Mar 2015
      • 171
      • india
      thanks for the reply .will try to program itand see the ic is very costly here in india
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Yes this costs somewhere around $15 and i warn every member on this forum that you should include atleast 2 sio's cost before giving an estimate for repair as long as sio is KB904X/KB905X.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
          03-31-2024, 02:12 PM
        • mkdj
          Acer TravelMate P214 - N19Q7 main power rail shorted to ground
          by mkdj
          Dear all,
          I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
          I have checked resistance across each of the 4 MOSFETS. I have the following readings:
          Both N-Channel Mosfets: nothing odd
          P-Channel MOSFET number 1:
          source - drain : 117 kOhm
          source - gate: 96 Ohm
          gate - drain: 117 kOhm
          P-Channel MOSFET...
          08-20-2025, 06:08 AM
