Acer Swift sf314-51-55 doesn't start
  • giulio93
    • Aug 2021
    • 258
    • Italy
    #41
    Re: Acer Swift sf314-51-55 doesn't start
    YES.That R010 is very likely the CLR(Current sensing resistor). You should have stable 19V here. If your 3v/5V PWM is soldered properly and the chip is ok, then you have problem in charging section.
    Take the following steps:
    01.Identify the 2 dc-in mosfets and measure voltage on them.
    02.Check in resistance mode(both fets) between
    A=Source -Drain
    B=Source - Gate
    C=Gate -Drain
    03.Locate the charging IC and check these pins
    A=VCC
    B=REGN
    C=ACOK
    D=ACDET
    E=CMSRC
    Link the schematic so that i can answer better.
    vcc=18.9
    B=6.2
    C=0
    D=2.6
    E=0
    for the 2 mosf i think they are those on the right of the current sensor resistor. I have all Kohm mesure but the one connected to the same pad.
    and now i have no more vin at the 1225c
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      #42
      Remove the CLR and then connect the adapter. Do you get 25V at the gate of both dc-in fets?
      • giulio93
        • Aug 2021
        • 258
        • Italy
        #43
        They are no "normale mosfs" with one gate. But no, i dont have the 25V. But i have some 19V around the Board.
        And why Now i dont have anymore the vin at the stepdown?
        • giulio93
          • Aug 2021
          • 258
          • Italy
          #44
          i dont get a thing. the vc in on the 1225c comes directly from the dc in connector or the bq chip has to be activated?
          • giulio93
            • Aug 2021
            • 258
            • Italy
            #45
            there is any difference between bq735 and bq736?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #46
              It comes from CLR and not dc jack directly. If you dont have 19V on CLR, you wont get it at stepdown controller. Whether voltage will reach CLR or not, depends on the functioning of charging circuit.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #47
                Yes, not compatible.
                • giulio93
                  • Aug 2021
                  • 258
                  • Italy
                  #48
                  At this point i think the problem is the bq. AM i correct?
                  Do you confirm the 2 input mosfets are the nearby of the clr?
                  other thing. Why i have not the 19V At the first mosfet?
                  • giulio93
                    • Aug 2021
                    • 258
                    • Italy
                    #49
                    At least I aspected ti have the 19V on ine of the 2 mosfet
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #50
                      That expectation will meet on the board when charging circuit works. Why not give us measurement of charging IC instead of what you expect or think? That'll perhaps help you. Without measurements our guess is as good as yours.
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        #51
                        I already gave you the masure of the charging i you asked me
                        • giulio93
                          • Aug 2021
                          • 258
                          • Italy
                          #52
                          I'm trying to solder the new bq chip but the solder does not stay on it... I think it is a bar quality chip. Do you have any tips to solve this problem?
                          • Sephir0th
                            • Oct 2020
                            • 1266
                            it's a common issue with these controllers. Try to pre-tin the pads of the IC and try again. it should help till some extent
                            FairRepair on YouTube
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #54
                              If the IC is new, you have to apply flux on it and put some solder with a irn tip.The solder will stick and pins will shine up. Remove any excess solder with a soldering braid. Now ready to go. Once again apply flux on the pcb pads,align the IC with pcb and then apply heat.It should be properly soldered. Touch up the pins if you doubt any connectivity issues.
                              • giulio93
                                • Aug 2021
                                • 258
                                • Italy
                                #55
                                I've tried but The solder simoly doesnt stay on the pins
                                • Sephir0th
                                  • Oct 2020
                                  • 1266
                                  You need to be more Patient with the pins. It will work after a while.
                                  • giulio93
                                    • Aug 2021
                                    • 258
                                    • Italy
                                    #57
                                    I stay more then 10sec on each pin with the solder iron
                                    • giulio93
                                      • Aug 2021
                                      • 258
                                      • Italy
                                      #58
                                      I solder and resoldered manu Times. I get 2.8-3.8v in the current sensor. I have the same tension on the gate of the Second mosfet (i think the Second) and 0 at the first. I dont understand why i have no 19V in the input of the first mosfet. In add, i am not sure of the bq soldering couse of the problem i described 2some message ago.
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        #59
                                        Considering your stuggle with even soldering a chip,i'll strongly suggest to take it to some professional. An unproperly soldered chip may take you down to a rabbit hole in diagnosis.
                                        • giulio93
                                          • Aug 2021
                                          • 258
                                          • Italy
                                          #60
                                          The problem is the chip. I'm soldering from 10 yeas now and i never had this kind of problem. I see many other people having trouble in soldering in this period, especially with china chips
