Acer Swift sf314-51-55 doesn't start
  • giulio93
    • Aug 2021
    • 258
    • Italy
    Hi everyone, I have a problem with this pc. The problem is so strage so I Will try to do my best. The pc doesn't start. The 3.3 on keybord and on a couple of caps bear the i/o chip is present. When I press the power Button the 3.3 on keybord went to 0 but the pc doesn't start. If i pluged the charger no lights show off. I try to use my lab power supply and in this case The pc starts and charges. Now If I Plug the standard charger the pc get the charge (led on) and if i press the power Button the pc starts. In this state I can start the pc for a agile but last evening the pc works Now don't. What can be the problem? Can you help me please? Thank you all
  • mon2
    • Dec 2019
    • 13989
    Re: Acer Swift sf314-51-55 doesn't start
    Test with another recommended power adapter. Sounds like the original is flaky since the lab power supply works.
    • giulio93
      • Aug 2021
      • 258
      • Italy
      But also with the battery the laptop doesn't turn on.
      to recap: with My lab power supply The laptop works and it still works for a while (with The battery too). After a while The laptop seems to be Death.
      • giulio93
        • Aug 2021
        • 258
        • Italy
        When I say that the laptop works I mean that it turn on and off normally
        • natic
          • Sep 2018
          • 34
          • EU
          Hello!
          Please, specify the motherboard marking code.
          • giulio93
            • Aug 2021
            • 258
            • Italy
            Originally posted by natic
            Hello!
            I attached the pics.
            New observation: when the battery is plugged the chip I post the pic goes to 43 degree. If I disconnect the battery it doesn't happen. Charger plugged in or nor no differences
            • giulio93
              • Aug 2021
              • 258
              • Italy
              Errata corrige, when both the battery and the charger are connected the temp reach 46. On the caos near to it i have 5v and 3.3V.
              other thing, when just The charger is plug in (battery disconnected) The Board emitt a "click" every Second ish. And in this situation a Little spot goes hot around 35 Deg. Tomorrov i'll send The pic
              • giulio93
                • Aug 2021
                • 258
                • Italy
                With just fhe charger plugged in the vin of this chip goes up and down from 2.8V to 3.8.
                I tried to inject 3.3 on the 3.3V line and the line absorb 0.028A. It is not to much?
                • mon2
                  • Dec 2019
                  • 13989
                  Where exactly is this voltage pulsing?
                  If it is a 3v3 rail, then 3v8 is too high and may have damaged some parts on this rail.
                  • giulio93
                    • Aug 2021
                    • 258
                    • Italy
                    Sorry, The rail pulging is The Vin so the 19V
                    • mon2
                      • Dec 2019
                      • 13989
                      Remove all power. Meter in resistance mode. Measure the resistance to ground at the DC-in power adapter connector pin.
                      What is the resistance to ground?
                      See attached - are these arrow points pulsing?
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        Without The Board view it's hard for me understand where the arrows are in the logic Board. Can you Point me the mesure Point in the pics I share?
                        • mon2
                          • Dec 2019
                          • 13989
                          Remove all power -> measure the resistance to ground of where you have seen the Vin rail pulsing. What is the resistance?
                          • natic
                            • Sep 2018
                            • 34
                            • EU
                            Measure the resistance to ground on any pin of marked resistor.
                            • giulio93
                              • Aug 2021
                              • 258
                              • Italy
                              Tell me if i missunderstand. I check on schematic of the 1225c and the pin 12 should be this one.
                              • giulio93
                                • Aug 2021
                                • 258
                                • Italy
                                2.48 Mohm
                                • mon2
                                  • Dec 2019
                                  • 13989
                                  To confirm, the adapter voltage of 19v is pulsing at the connector where there are the 2 x red wires?
                                  Is the power adapter the original and the one recommended for use with this laptop? If the adapter is underrated, the power rail will dip.
                                  • natic
                                    • Sep 2018
                                    • 34
                                    • EU
                                    True.
                                    Please, post a picture of the hot spot.
                                    • giulio93
                                      • Aug 2021
                                      • 258
                                      • Italy
                                      No is not pulsing At The connector. The adapter is a compatibile one with 2.37A
                                      • giulio93
                                        • Aug 2021
                                        • 258
                                        • Italy
                                        True.
                                        Here
