Help with this FPC connector 820-01521-A
  • arsengames
    • Sep 2023
    • 4
    Hello everybody. Working on a donor board of a 820-01521-A and kinda got stuck while removing the USB-C FPC connector. I am now wondering how to properly remove it from the board (without damaging it) and what about putting it back on the motherboard? I thought of applying heat from the other side of the board in the area where the FPC connector is located, but there is just too many components that will shift around when the heat is applied.
    Any help will be appreciated!
    Last edited by SMDFlea; 09-08-2023, 05:15 AM. Reason: Added "820-01521-A" to thread title,moved thread to laptop forum
  • ugamazing
    • Jun 2013
    • 171
    • usa
    Re: Help with this FPC connector 820-01521-A
    Remove it with an IR preheater. Best way to pull things from these boards. The PCB is too good at sinking heat to use traditional "heat below board" to remove these connectors, and the inset pins make applying low-melt solder to the pins impossible. Preheater is 100% the way to go.
    • arsengames
      • Sep 2023
      • 4
      Thank you, will look into that!
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
      • 5mall5nail5
        Help identifying connector for ASUS 4090 Strix RGB LED connector
        by 5mall5nail5
        Hi All -
        I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
        Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
        05-04-2025, 07:47 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
        Securing a good thermal interface between...
        10-07-2024, 04:35 AM
      • bussincaps
        MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
        by bussincaps
        Hello All,
        tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
        Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
        eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
        Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
        I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
        08-03-2023, 12:57 PM
