Acer Nitro 5 Dead
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Acer Nitro 5 Dead
    hi guys I have the above laptop
    Acer Nitro 5 AN515-45
    its dead as a dodo.
    im not sure where to begin checking for shorts.
    can anyone help ??
    many thanks
    Jason
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • Roti
    • Jun 2017
    • 21
    • Poland
    Re: Acer Nitro 5 Dead
    Measure the voltages and resistances from all coils. Is the motherboard LA-H501P? How much current does the motherboard take when plugged in?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Check for 3.3v on battery connector first, with adapter plugged in. That way we can get an idea where to start measuring.
      A working TV? How boring!
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Does 19V crosses after first dc-in mosfet?
        • jasonr2000
          Advance Tech
          • Nov 2013
          • 209
          yes its the LA-H501P motherboard.
          and ok ill check for that thanks
          thanks ill check for that also today
          Samsung UE46D6530
          Samsung BD-F7500
          Samsung HT-ES6200
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 209
            there are the readings for the resistance
            hi thanks for the reply I have my meter set to 2000 ohms
            and get the following readings
            PL301 34 ohms
            PL501 my meter shows it counting up then 1 (I think means out of range)
            PLB1 my meter shows it counting up then 1 (I think means out of range)
            PL1101 30 ohms
            PCV36 my meter shows it counting up then 1 (I think means out of range)
            PLW1 144 ohms
            PLV2 26 ohms
            PLV3 24 ohms
            PCV139 33 ohms
            PLH1 52 ohms
            PLA1 35 ohms
            PLZ4 34 ohms
            PLZ3 32 ohms
            PLZ2 33 ohms
            PLZ1 33 ohms
            PLG1 37 ohms
            PCZ47 my meter shows it counting up then 1 (I think means out of range)
            PLM1 311 ohms
            UV49 measures 440 ohms pins 5 6
            UV49 measures pin 1 no reading pin 2 1356 ohms
            UH2 measures pin 1 no reading pin 2 646 ohms
            UH2 measurers pin 5 27 ohms pin 6 571 ohms
            all the reaadings was done with my meter set to 2000 ohms
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
            • jasonr2000
              Advance Tech
              • Nov 2013
              • 209
              im getting the following on the battery connector 0.27v
              yes its passing the first dc-in mosfet.
              Samsung UE46D6530
              Samsung BD-F7500
              Samsung HT-ES6200
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Locate the 3V PWM and check for +3V LDO present or not
                • jasonr2000
                  Advance Tech
                  • Nov 2013
                  • 209
                  +3V ALW isn't there.
                  Samsung UE46D6530
                  Samsung BD-F7500
                  Samsung HT-ES6200
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I didnt ask for 3V ALW. You need to look for 3V LDO(+3V LP).
                    • jasonr2000
                      Advance Tech
                      • Nov 2013
                      • 209
                      hi again +3V LP isn't there I don't have a 3V LDO ??
                      Samsung UE46D6530
                      Samsung BD-F7500
                      Samsung HT-ES6200
                      • mon2
                        • Dec 2019
                        • 14261
                        The 3v3 LDO is often a local rail on the same controller IC. Being a ldo, usually the current support is low to power a small circuit.
                        If this LDO rail is not active, check the enable pins for this controller and their voltage to ground. Share the part markings of this regulator ic so we can check the datasheet. Also check the resistance to ground of the non-working voltage rail(s).
                        • jasonr2000
                          Advance Tech
                          • Nov 2013
                          • 209
                          I have 4.5v on ENLDO 3V5V is that the correct rail ??
                          Samsung UE46D6530
                          Samsung BD-F7500
                          Samsung HT-ES6200
                          • jasonr2000
                            Advance Tech
                            • Nov 2013
                            • 209
                            ok I've found 3v3 LDO and its showing nothing.
                            in ohms mode it says 530 ohms
                            I can't read the chip sadly its soo small.
                            Samsung UE46D6530
                            Samsung BD-F7500
                            Samsung HT-ES6200
                            • mon2
                              • Dec 2019
                              • 14261
                              Post a picture of the LDO. I think I have the schematic of this unit in my paid sub.
                              • Roti
                                • Jun 2017
                                • 21
                                • Poland
                                Measure the voltage on pin: 2, 9, 11, 12, 17 and 20 PU301. With the motherboard off, measure the resistance to ground at n.8 UH2
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  If 3V LDO rail resistance to GND is indeed 530 Ohms, then its shorted. the resistance here should be in Kohms. Very likely a shorted EC.
                                  • jasonr2000
                                    Advance Tech
                                    • Nov 2013
                                    • 209
                                    sorry for the slow reply guys ive had a busy few days.
                                    I believe this is the LDO
                                    Samsung UE46D6530
                                    Samsung BD-F7500
                                    Samsung HT-ES6200
                                    • jasonr2000
                                      Advance Tech
                                      • Nov 2013
                                      • 209
                                      pin 8 0n UH2 is 0 ohms
                                      pin 2 = 19V
                                      pin 9 = 0v
                                      pin 11 = 4.06v
                                      pin 12 = 0v
                                      pin 17 = 0v
                                      pin 20 = 0v
                                      Samsung UE46D6530
                                      Samsung BD-F7500
                                      Samsung HT-ES6200
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        You can look in schematic or datasheet for +3V LP pin of PWM. Its been days and you still cant confirm whether its present or not and its resistance to GND. All suggestions have been given.Where are your follow ups?
