A2289 No power.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    A2289 No power.
    No water damage on board.
    Customer came in with board dead.
    5.20V
    0.00Amps
    Sometimes I see a .03amp and it jumps to .46A and then resets to zero.
    Customer stated they used a knock off charger but both chips seem fine and are reading fine. Checked readings
    PPBUS_G3H is present
    PP3V3_G3H is present
    PP1V8_SLP is present
    Awake is present
    PP5V_G3S is not present
    Tested USB C readings on UEM2. Comes up good.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Re: A2289 No power.
    Tested ppbus_G3H voltage is 12.23Volts
    Check wiki and it says if it’s below 12.60 it’s a T2 issue?
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 667
      Re: A2289 No power.
      So far what I’m pointing at is a bad ISL9240 wish me luck
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 667
        Re: A2289 No power.
        Replaced ISL9240 chip, no power. but now have a constant .03 amps 5.20volts
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 667
          Re: A2289 No power.
          Going to replace CD3217 chips. Seems to me all power rails are present, going to assume both chips are bad. Hopefully this solves this problem
          sigpic
          • mon2
            • Dec 2019
            • 14097
            Re: A2289 No power.
            Check the LDO rails of each CD3217. Check the USB / CCx port pins in DIODE mode.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 667
              Re: A2289 No power.
              LDO rails present and normal.
              Diode Mode normal. CD3217 seems to be the issue then.
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 667
                Re: A2289 No power.
                UPDATE: Replaced both CD3217 chips.
                still 5.15v
                0.03 Amps
                HOWEVER, the amps jump to .96 consistently now. No idea whats going on. I would know if it was consistent .31 amps etc. but it just keeps dropping to .0A or .03 Amp then jumps to .96a then sometimes .63 and up and still no 20volts. This is a better look than last week on this board but now i feel i am getting closer to fixing it but I am still dumbfounded. lol
                also i am hearing a clicking noise when plugged in. You can hear it go click, click click. near the T2 chip area
                Put thermal camera on, found the little bastard!
                Cap C4400 was blown and pumping 120F then dropping with alcohol on it.
                and now she is on
                Last edited by Vesko356; 08-25-2023, 11:04 AM. Reason: 5 (five) posts merged. Again!!!
                sigpic
                • mon2
                  • Dec 2019
                  • 14097
                  Re: A2289 No power.
                  Well done!
                  • javieromex
                    Dell G15 5511 LA-K452P won't turn on
                    by javieromex
                    Hello, any help will be apprecited!
                    • Model: Dell G15 5511
                    • MB: LA-K452P
                    • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                    • Customer reported it was turned off and left plugged in during the night and thats it...
                    • No signs of liquid damage or burned components.
                    Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                    I have checked so far:
                    04-17-2025, 12:44 PM
                  • mecha1166
                    Anyone here fix a tv and customer cracks panel when they get it home?
                    by mecha1166
                    About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
                    03-29-2024, 11:27 AM
                  • valente222
                    HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                    by valente222
                    I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                    there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                    n, please identify.
                    330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                    SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                    I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                    06-27-2024, 06:11 PM
                  • air_chair256
                    Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
                    by air_chair256
                    I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
                    Tried to reball RAM 1,2,3,4
                    Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
                    02-13-2024, 06:00 AM
                  • Prott
                    Surface Pro 7 - SLP_S4 present, then gone
                    by Prott
                    Hello fellow Badcappers,
                    I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
                    Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
                    12-03-2023, 06:11 PM
