A2289 No power.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    A2289 No power.
    No water damage on board.
    Customer came in with board dead.
    5.20V
    0.00Amps
    Sometimes I see a .03amp and it jumps to .46A and then resets to zero.
    Customer stated they used a knock off charger but both chips seem fine and are reading fine. Checked readings
    PPBUS_G3H is present
    PP3V3_G3H is present
    PP1V8_SLP is present
    Awake is present
    PP5V_G3S is not present
    Tested USB C readings on UEM2. Comes up good.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: A2289 No power.
    Tested ppbus_G3H voltage is 12.23Volts
    Check wiki and it says if it’s below 12.60 it’s a T2 issue?
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Re: A2289 No power.
      So far what I’m pointing at is a bad ISL9240 wish me luck
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Re: A2289 No power.
        Replaced ISL9240 chip, no power. but now have a constant .03 amps 5.20volts
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Re: A2289 No power.
          Going to replace CD3217 chips. Seems to me all power rails are present, going to assume both chips are bad. Hopefully this solves this problem
          sigpic
          • mon2
            • 14659
            Re: A2289 No power.
            Check the LDO rails of each CD3217. Check the USB / CCx port pins in DIODE mode.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Re: A2289 No power.
              LDO rails present and normal.
              Diode Mode normal. CD3217 seems to be the issue then.
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                Re: A2289 No power.
                UPDATE: Replaced both CD3217 chips.
                still 5.15v
                0.03 Amps
                HOWEVER, the amps jump to .96 consistently now. No idea whats going on. I would know if it was consistent .31 amps etc. but it just keeps dropping to .0A or .03 Amp then jumps to .96a then sometimes .63 and up and still no 20volts. This is a better look than last week on this board but now i feel i am getting closer to fixing it but I am still dumbfounded. lol
                also i am hearing a clicking noise when plugged in. You can hear it go click, click click. near the T2 chip area
                Put thermal camera on, found the little bastard!
                Cap C4400 was blown and pumping 120F then dropping with alcohol on it.
                and now she is on
                Last edited by Vesko356; 08-25-2023, 11:04 AM. Reason: 5 (five) posts merged. Again!!!
                sigpic
                • mon2
                  • 14659
                  Re: A2289 No power.
                  Well done!
