Macbook A1706 Battery Service Issue
  • Instafixx
    • Jul 2022
    • 374
    • India
    Namaste.
    I have a Macbook A1706 . Whenever i replace the battery i am getting service recommended. The same battery on the other device shows Normal Condition.
    The small flex in this model is soldered onto the battery flex.
    I don't understand what the issue is.
  • Adogabriel100
    knowledge seeke
    • Aug 2021
    • 36
    • peru
    Re: Macbook A1706 Battery Service Issue
    are you trying a new or used battery?
    How many charge cycles on the battery ?
    • Instafixx
      • Jul 2022
      • 374
      • India
      New Battery with 2 charge cycles.
      • mon2
        • 14681
        Post the voltage to ground of each battery connector pin on the logic board.
        • Simone Vergani
          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
          by Simone Vergani
          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
          To assist with troubleshooting, I'm attaching two power circuit schematics:
          • Power
          03-05-2025, 02:25 PM
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • mkdj
          by mkdj
          Mark and model: ASUS X571
          Tests already made:
          - I have removed...
          07-14-2025, 09:16 AM
        • drlarsen
          MacBook Air M1 A2337 battery/charging issue
          by drlarsen
          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
          After some hours, the battery status did not improve. Restore via DFU did not help.
          I connected the power adapter to a Kill-a-Watt...
          07-17-2025, 02:35 PM
        • mferna14
          Macbook Pro A1706 not turning on with battery
          by mferna14
          Hi., today working on a Apple MacBook Macbook Pro A1706 (Board part # 820-00239-A) not turning ON with battery. The notebook turns on 100% fine with USB-C Power adapter (NO BATTERY INSTALLED), boots up well & all seems to be perfect. I connect J6950 to the main battery terminal & it's fine, boots up well but does not work with battery as till now the MB did not detect the battery & no battery icon shows up. As soon as I connect the BDM battery flex cable to J6951, the ampmeter display goes on & off & takes only 5v & this is in a loop (display comes & goes after detecting...
          10-19-2023, 03:39 PM
