Motorola G22 Boot issue
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hello morning afternoon or evening, Whenever you are viewing this post.
    Phone Motorola G22 only workswell when plugged into the mains/power bank, Also, charges normal, On normal switch without mains/power bank on it just reboots the moto symbol, goes on/off in a loop.
    I have not restored the handset and I'm not sure about reflashing, Also in recovery mode comes up with the Android red triangle and No command.
    Can anyone, suggest what maybe the issue or issues and advise please.
    Thank you
  • abajor
    Alienware Area-51 R2 Boot Loop issue.
    by abajor
    I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
    It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
    To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
    Right now I'm trying to dig through the PDF schematics and Board...
    03-08-2024, 10:08 PM
  • Safio
    Asus Rog Strix g15 g512LI BOOT ISSUE
    by Safio
    Hello
    My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
    i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
    thank you
    06-08-2024, 08:43 PM
  • javierwilliam
    Boot loop issue with LCD TV
    by javierwilliam
    I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
    Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
    Thanks in advance!​
    08-29-2024, 04:06 AM
  • lukkihapsi
    Asus Vivobook X515JA Weird Boot Issue
    by lukkihapsi
    Asus Vivobook X515JA Laptop
    Issue :
    Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
    Tried :
    Cleaned inside for dust, applied fresh thermal paste. No Change!
    Removed keyboard, Trackpad, fingerprint sensor. No Change!
    Removed Internal SSD. No Change!
    Updated BIOS to latest version. No Change!
    Removed battery and pressing power button for 1 minute. No Change!
    Weird Part :
    Upon turning laptop ON, screen lights up - stays black,
    I...
    07-07-2025, 12:07 PM
  • Stephen
    iMac 27” 2020 Boot issue
    by Stephen
    Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
    08-16-2024, 09:32 AM
