HP 840 G5 not detecting sound chip
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    i replaced chip with used but still no joy. no schem and datasheet fit it
  • mon2
    • 14671
    Re: HP 840 G5 not detecting sound chip
    Which sound chip?
    What are the markings on your logic board?
    Sometimes you can review other logic boards from the same vendor as they are similar.
    Post a pic of the replaced audio chip on your logic board.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      sry . chip is CX7750
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • korben_dallas
        Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
        by korben_dallas
        Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
        I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
        I'm new to soldering but the only feasible way to fix this issue is to do something myself.
        MY QUESTION:
        I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
        02-14-2024, 12:23 AM
      • Stephen
        A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
        by Stephen
        As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
        5.16V .47amp
        5.16V .47amp
        5.16V .47amp
        5.16V .04amp (this guy is the issue) (U3200)
        So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
        11-27-2023, 03:57 PM
