820-01958 no charging
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    hi all,
    i am working on macbook air A2179 820-01958.
    problem: no charging. usb amp meter 5V and 0.3A both and upside down.
    if using original battery, sometimes shows battery sign.
    if using neww battery can booting but still get 5V and 3A.
    there is no sign of water damage or liquid.
    measurement:
    PP3V3_G3H_RTC = 3.25V
    PP3V3_UPC_T_LDO = 3.2V
    PP1V5_UPC_T_LDO_CORE = 1.57V
    USBC_T_CC2 = 1.39V
    USBC_T_CC1 = 0V (6.3MOhm for diode mode)
    PPDCIN_G3H = 4.9V
    PP20V_USBC_T_VBUS = 0V (0.5 KOhm for diode mode)
    PP5V_G3S = 0V (13 KOhm for diode mode)
    the measurement is the same for another ic.
    for this problem should i just replace the cd3217 ?
  • mon2
    • 13995
    Re: 820-01958 no charging
    After a normal boot, do you see the battery details? Can you view the battery serial number,number of charge cycles, etc. ? This is important.
    Carefully measure the voltage to ground of each pin on the battery connector. Post all measurements.
    Interested to confirm the SMbus lines are ok (SCL and SDA).
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      yes @mon2, with new battery installed, i get 5V and 0A but i can power on with power button. and i can see the battery information such as cc, batt serial number etc.
      without battery
      SMSBUS_3V3_BATT_SCL = 3.2V
      SMSBUS_3V3_BATT_SDA = 3.2V
      SYS_DETECT_L = 0V
      with battery
      SYS_DETECT_L = 0V
      PPVBAT_G3H_CONN = 11.55V
      PPVBAT_G3H_CONN = 0.3V
      • mon2
        • 13995
        I think you may have corrupted firmware. Do attempt and post your updates:
        https://www.badcaps.net/forum/showthread.php?p=1148844
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          hi@mon2,
          usually when i only get 5v, i can not get into DFU mode.
          is there any chance that i get corrupted usb c ROM chip (U3060)?
          • mon2
            • 13995
            Confirm the LDO rails on each ACE controller (cd3217). Each ACE controller must be working to dial up the 20v power delivery contract from the external power adapter.
            On the firmware bios, check the voltage to ground of each pin.
            • kingskie
              • Oct 2014
              • 249
              • indonesia
              LDO rails all are ok.
              BIOS (U4770)
              - PP1V8_AWAKE = 1.79V
              - SPI_SOCROM_CLK = 0.026V
              - SPI_SOCROM_MOSI = 1.79V
              - SPI_SOCROM_CSL = 1.79V
              - SPI_SOCROM_MUX_MISO_R = 1.79V
              - SPI_SOCROM_WP_L = 1.79V
              P.S. i flashed the USB C ROM chip but still get 5V and 0.3A
              • mon2
                • 13995
                Confirm the SPI_SOCROM_CLK line at other points of this trace. The voltage should not be stuck low unless the SPI bus master is not oscillating.
                • kingskie
                  • Oct 2014
                  • 249
                  • indonesia
                  what should i do now?flash the bios?
                  can the not charging issue related to bios?
                  • mon2
                    • 13995
                    1) Check the voltage to ground on each side of R4172.
                    2) Remove all power. Measure the resistance between R4172, pin # 1 and U4770, pin #6. This is to confirm the trace is still present between these 2 points of interest.
                    • kingskie
                      • Oct 2014
                      • 249
                      • indonesia
                      1. R4172 both sides have 1,8V
                      2. 2.9Kohm
                      • mon2
                        • 13995
                        Confirm the same voltage is present at pin SPI_SOCROM_CLK on the flash ic.
                        • mon2
                          • 13995
                          Also, the resistance is not correct as measured. According to the schematic, the R4172 resistor should be ~20 ohms. Confirm this measurement again.
                          Do compare the resistance of R4171 which should be also ~20 ohms.
                          • kingskie
                            • Oct 2014
                            • 249
                            • indonesia
                            confirm the same voltage is present at pin spi_socrom_clk on the flash ic.
                            spi_socrom_clk = 0.026v
                            • kingskie
                              • Oct 2014
                              • 249
                              • indonesia
                              i am so sorry @mon2, i measure on the wrong part (R4712)
                              i just measure now R4172 and R4171 is 20 ohms
                              voltage on R4172 = 0.014V (pin 1) and 0.026V (pin 2)
                              • kingskie
                                • Oct 2014
                                • 249
                                • indonesia
                                i was curious so i replaced 2 usb c ic and still the same problem.
                                • kingskie
                                  • Oct 2014
                                  • 249
                                  • indonesia
                                  anyone?
                                  • kingskie
                                    • Oct 2014
                                    • 249
                                    • indonesia
                                    update:
                                    DFU mode - revive - got error 4042.
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • Julian Bailey
                                      HP ProBook 445 G8 Battery not charging
                                      by Julian Bailey
                                      Hi all
                                      We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                      The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                      I have gone around the board with a MM and cant find anything
                                      Windows shows the battery fine,...
                                      10-11-2024, 10:34 AM
                                    • piernov
                                      Laptop battery charging circuit
                                      by piernov
                                      1. Some theory
                                      1.1. Introduction
                                      Almost every laptop has a charging circuit of some sort, that does a few things:
                                      • Manages switching between AC adapter and battery power
                                      • Manages battery charging and generates power rail to charge battery
                                      There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                      • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                      • Narrow VDC (NVDC)
                                      Texas instrument has a nice overview of these technologies with some more details at https:...
                                      11-15-2020, 01:31 PM
                                    • kodox
                                      ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                                      by kodox
                                      since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                                      the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                                      what i've done:
                                      - flashing...
                                      12-29-2024, 02:49 AM
                                    • Shinju
                                      Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                      by Shinju
                                      Hey All!
                                      Long time forum member here with a problematic laptop issue!
                                      I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                      The laptop would not power on with the new battery installed without the power supply being plugged in.
                                      When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                      TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                      10-20-2021, 04:58 PM
